Air purifier 3 -read data
I have an air purifier 3. I am now connected to the unit (I found the token). I control the device (ON, OFF ...).
I do not know how to set the data reading from the device. (air quality, temperature, humidity)
Hi @Miko7
Your question doesn't give us very much information to help you.
What is an air purifier 3? Do you have a link to any relevant documentation? How are you connecting to the device? What nodes are you using?
Sorry. I use this node https://flows.nodered.org/node/node-red-contrib-mi-air-purifier3. Thanks
There isn't much information in that nodes README. Have you put a debug node (set to display 'Complete msg object') on it's output to see what comes back?
