I will try change payload from mqtt into a number!
[{"id":"586b0b1cae11d462","type":"tab","label":"Flow 10","disabled":false,"info":"","env":[]},{"id":"067ae491e9e74a98","type":"mqtt in","z":"586b0b1cae11d462","name":"Temperatura","topic":"IPB/IoT/Farm/AirQuality/Temperatura","qos":"2","datatype":"auto","broker":"0cf85d5ab020f8be","nl":false,"rap":true,"rh":0,"inputs":0,"x":410,"y":220,"wires":[["e47c57ab488506a2","dd58c64aa7242471","0457cb2fabce1801","6a978807825d513c"]]},{"id":"dd58c64aa7242471","type":"ui_gauge","z":"586b0b1cae11d462","name":"Medidor","group":"aedd66b9cb7dc5a6","order":1,"width":0,"height":0,"gtype":"gage","title":"Temperatura","label":"ºC","format":"{{value}}","min":"-10","max":"50","colors":["#00b500","#e6e600","#ca3838"],"seg1":"13","seg2":"20","className":"","x":720,"y":280,"wires":[]},{"id":"e47c57ab488506a2","type":"debug","z":"586b0b1cae11d462","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":730,"y":160,"wires":[]},{"id":"0457cb2fabce1801","type":"ui_chart","z":"586b0b1cae11d462","name":"Grafico","group":"408f2e307a2c3dfb","order":1,"width":0,"height":0,"label":"Temperatura","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"86400","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"className":"","x":720,"y":240,"wires":[[]]},{"id":"6a978807825d513c","type":"function","z":"586b0b1cae11d462","name":"","func":"let temp = msg.payload\n\nif (temp>=10 && temp<=26) {\n msg.payload = \"O alimento pode ser transportado\"\n} else {\n msg.payload = \"O alimento não pode ser transportado\"\n}\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":720,"y":200,"wires":[["7e6f1685b5aadcb5"]]},{"id":"77d730aa29c52479","type":"mqtt in","z":"586b0b1cae11d462","name":"Humidade","topic":"IPB/IoT/Farm/AirQuality/Humidade","qos":"2","datatype":"auto","broker":"0cf85d5ab020f8be","nl":false,"rap":true,"rh":0,"inputs":0,"x":400,"y":420,"wires":[["e82a0c767befca6b","ce8bc268a9b7dd2a","dd8f0cdbc52558e6","041b74cd768aaca6"]]},{"id":"e82a0c767befca6b","type":"ui_gauge","z":"586b0b1cae11d462","name":"Medidor","group":"aedd66b9cb7dc5a6","order":2,"width":0,"height":0,"gtype":"wave","title":"Humidade","label":"%","format":"{{value}}","min":0,"max":"100","colors":["#e543b2","#ffffff","#ffffff"],"seg1":"","seg2":"","className":"","x":720,"y":480,"wires":[]},{"id":"ce8bc268a9b7dd2a","type":"ui_chart","z":"586b0b1cae11d462","name":"Gráfico","group":"408f2e307a2c3dfb","order":2,"width":0,"height":0,"label":"Humidade","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"86400","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"className":"","x":720,"y":440,"wires":[[]]},{"id":"dd8f0cdbc52558e6","type":"debug","z":"586b0b1cae11d462","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":730,"y":360,"wires":[]},{"id":"041b74cd768aaca6","type":"function","z":"586b0b1cae11d462","name":"","func":"let hum = msg.payload\n\nif (hum>=40 && hum<=45) {\n msg.payload = \"Food can be transported\"\n} else {\n msg.payload = \"Food can't be transported\"\n}\n\nreturn msg;\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":720,"y":400,"wires":[["7e6f1685b5aadcb5"]]},{"id":"7e6f1685b5aadcb5","type":"ui_toast","z":"586b0b1cae11d462","position":"top right","displayTime":"3","highlight":"","sendall":true,"outputs":0,"ok":"OK","cancel":"","raw":false,"className":"","topic":"","name":"","x":1220,"y":320,"wires":[]},{"id":"0cf85d5ab020f8be","type":"mqtt-broker","name":"","broker":"broker.mqtt-dashboard.com","port":"1883","clientid":"","autoConnect":true,"usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"sessionExpiry":""},{"id":"aedd66b9cb7dc5a6","type":"ui_group","name":"Medidor","tab":"3ca0c34b.d48204","order":1,"disp":true,"width":"6","collapse":false,"className":""},{"id":"408f2e307a2c3dfb","type":"ui_group","name":"Gráfico","tab":"3ca0c34b.d48204","order":2,"disp":true,"width":"6","collapse":false,"className":""},{"id":"3ca0c34b.d48204","type":"ui_tab","name":"Produção Primária","icon":"dashboard","disabled":false,"hidden":false}]
