Hoping I can get your help with a simple issue. I have a configured both Alexa and Viera (node-red add-ons) and want to use Alexa to change the volume of my tv.
I know I need the value "bri" but this needs to be sent as a string to the Viera add on. For the life of me, I can't figure out how to send this as a string.
I think one major issue is that the debug request only accepts an object so this means it's very hard to test.
I have exported my config here.
The payload back from alexa for the TV Tv node is:
Blockquote
msg : Object
object
on: true
bri: 3
on_off_command: false
payload: "on"
change_direction: 0
bri_normalized: 0.03
device_name: "TV"
light_id: "cd9510e8e8e1f"
port: 41455
_msgid: "cb14f4b3.94ffd8"
the payload from a standard volume inject is:
Blockquote
msg : Object
object
_msgid: "9b6a5a50.2914a8"
topic: ""
payload: "10"
Flow
Blockquote
[{"id":"b7e668ac.002358","type":"viera write","z":"886ce33a.5e652","name":"setVolume","host":"10.0.0.x","function":"setVolume","x":730,"y":100,"wires":},{"id":"dc6fc9be.67ab18","type":"alexa-local","z":"886ce33a.5e652","devicename":"TV","inputtrigger":false,"x":230,"y":120,"wires":[["ffb17ab2.450068"]]},{"id":"7afcb8af.05aa18","type":"debug","z":"886ce33a.5e652","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":730,"y":140,"wires":},{"id":"ffb17ab2.450068","type":"function","z":"886ce33a.5e652","name":"","func":"return msg.payload[0].bri;","outputs":1,"noerr":0,"x":430,"y":140,"wires":[["7afcb8af.05aa18","b7e668ac.002358"]]}]
I have tried, in a function
1:
msg.payload = msg.payload[0].bri;
return msg.payload;
2:
msg.payload = msg.payload.bri
return msg.payload;
3:
Example TV config that works comes from:
