Alexa 'On Device Activity' not working
Is anyone else having a problem with Alexa 'On Device Activity' not working today (30/Aug/2023)?
I've swapped over to 'node-red-contrib-alexa-remote2-applestrudel' to see if the version I was using was the problem. No difference - the node says it is listening but doesn't react to my verbal commands.
Just checked and yep - looks like it stopped working just before midnight :frowning:
I can still make my Echo's speak but that's the only thing that is working
Hi Simon - thanks for your response. It's reassuring to know it's not my setup that is "playing-up".
Like you, I can make my Echo's speak. It's the 'Device Activity' that's not working (hiss, boo).
I also send text to mine using Routine Text Command and that's not working either (CORRECTON - it is working PEBKAC)
I've raised issues on applestrudel and remote2 repostires on GitHub
Ummm - that's strange. I can send a text string to mine and it/they "speak" the words fine, in fact every morning I send a customised weather report to the Alexa in my bedroom - works fine.
To clarify - I use 3 modes
Listening to whatever is said to Alexa - not working
Making an Echo speak - working
Sending text command to an Echo instead of verbally speaking - not working either (CORRECTION it is working PEBKAC)
I just tested and it OK for me ?
I hate it when something doesn't fail for everyone!
Would you mind stopping/starting NR and see if it still works?
You want me to try and break it :scream:
Will do :joy:
Works for me, and I restarted NR twice today.
But like for you, events aren't happening. Latest version, etc.
I'm a bit confused by your two posts - the 1st one says it working but your second implies it's not?
Great mine is broken now - Thanks :skull_and_crossbones: :skull_and_crossbones: :skull_and_crossbones:
I guess the issue shows iteself when the account node is initialised then. Hence some people working some not.
Very sorry :frowning: :frowning: :frowning:
Added a comment to the original issue #138 and copied in Apollon77 bbindreiter
#138 was last months issue - I feel this is a new one
Correction - my send text command to an Echo device is still working :slight_smile:
I forgot that it doesn't work if I try it out straight away after restarting NR (issue with my flow logic)
i have the same problem here! Its begins midnight! I'm from Brasil
same here!
