I have the following problem I get values from an Allen Bradley PLC.
If I want to use several variables in one function at the same time, it usually works like this:
this is output:
msg.payload = 22
msg.topic = 'value1'
if I now want to process the value in a function I do that by doing the following:
var test = msg.payload.value1
But a day at Allen Bradley looks like this e.g.
Local: 4: I.Ch0Data -> that is the topic
How can I achieve this?
If I do the following:
var test = msg.payload.Local: 4: I.Ch0Data
I get an error.
Thanks for pointing this out, but I can't find a solution to my problem there.
what do I have to do the node-red that puts together
"msg.payload.Local: 4: I.Ch0Data"
I assume he meant that you can use a Change node to do what you want. However I am not clear exactly what data you have to start with. Can you feed the message you have into a Debug node set to show Complete Message and show us what it shows please. Then tell us for that example exactly what you want to see in msg.payload (assuming that is where you want it).
