Alternative node for OPC UA Compact Server
I was using ' OPC UA Compact Server' in one of my Project, this project was handover two year ago.
Recently i was trying update OS of the image and stared updating my node-red application to it's latest nodes and flows, and looks like the 'OPC UA Compact Server' is no longer upgradable due o security concerns.
also, tried to install node-red-contrib-opcua-server-refresh 0.1.6 and it wasn't successful due to the security issues and it's been discontinued
2025-06-10T15:02:45.777Z Install : node-red-contrib-opcua-server-refresh 0.1.6
2025-06-10T15:02:47.560Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --omit=dev --engine-strict node-red-contrib-opcua-server-refresh@0.1.6
2025-06-10T15:03:17.999Z [err] npm
2025-06-10T15:03:18.000Z [err]  WARN deprecated vm2@3.9.19: The library contains critical security issues and should not be used for production! The maintenance of the project has been discontinued. Consider migrating your code to isolated-vm.
2025-06-10T15:03:34.419Z [err] npm
2025-06-10T15:03:34.420Z [err]  ERR! code 1
Is there any other node / flows which i could use instead of 'OPC UA Compact Server' develop and test ?
Your inputs highly appreciated.
Regards,
Mani
The discontinued notification is about a dependency (vm2) not the node-red-contrib-opcua-server-refresh node which was updated 2 months ago (it is not depreciated)
I have contacted @Hisma to see if it is something he would kindly look into.
You could try the newer node-red-opcua-x (node) - Node-RED it appears to have a node named opcua-server - though i have not tested it.
Hi @Steve-Mcl ,
Thanks for your quick response.
I did try to update the actual node'node-red-contrib-opcua-server' but got this below error messages.
I believe it's no longer supported due to security concern , the last update was nearly 3 yrs back.
that's a reason tried for the node-red-contrib-opcua-server-refresh got into the same issue.
2025-06-10T15:35:48.897Z Install : node-red-contrib-opcua-server 1.1.1
2025-06-10T15:35:50.641Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --omit=dev --engine-strict node-red-contrib-opcua-server@1.1.1
2025-06-10T15:36:25.261Z [err] npm
2025-06-10T15:36:25.262Z [err]  WARN deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
2025-06-10T15:36:25.833Z [err] npm
2025-06-10T15:36:25.834Z [err]  WARN deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
2025-06-10T15:36:26.152Z [err] npm
2025-06-10T15:36:26.153Z [err]  WARN deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
2025-06-10T15:36:28.140Z [err] npm
2025-06-10T15:36:28.141Z [err]  WARN deprecated vm2@3.9.19: The library contains critical security issues and should not be used for production! The maintenance of the project has been discontinued. Consider migrating your code to isolated-vm.
2025-06-10T15:36:42.435Z [err] npm
2025-06-10T15:36:42.436Z [err]  ERR! code 1
2025-06-10T15:36:42.436Z [err] npm ERR! path /var/lib/revpi-nodered/.node-red/node_modules/node-red-contrib-opcua-server
2025-06-10T15:36:42.451Z [err] npm
2025-06-10T15:36:42.453Z [err]  ERR! command failed
I have used quite a lot of logic structed code inside the 'address space' of this outdated opc ua compact server.
Thanks for the hit to use ' node-red-opcua-x' i will explored this option,
Also if possible any sample code to use 'OPCua-server' node with more variables would be highly appreciated.
@Hisma : Can you please guide me to update the application with the latest opc ua server ?
Regards,
Mani
Hey guys,
Thanks for the update. I did a dependency update a couple months ago, as @Steve-Mcl mentioned. I do recall getting warnings that vm2 was going to be deprecated and figured we'd eventually arrive here. But since this was a fork, I didn't want to completely refactor the code, and vm2 unfortunately handles some of the core node functionality, and the module it suggests to update is not backwards compatible with vm2. That said, let me revisit it and see if I can update it. I'll check this weekend.
Hi @Hisma ,
Thanks for taking a look over the upcoming weekend.
I’m looking forward to the update once it’s ready.
Best Regards,
Mani
Hi mister, good to speak again, its been a while - I hope you are well.
I wonder if you would also switch on issues for node-red-contrib-opcua-server-refresh so good folk can raise issues for your repo?
FYI
Issues are disabled by default in forked repositories. However, you can enable them by following these steps:
  1. Navigate to the Settings page of your forked repository.
  2. Click on the General tab on the left-hand side.
  3. Scroll down to the Features subsection.
  4. Check the box for Issues to enable them.
hI @Hisma ,
Would you able to fix the issue over the weekend ?
If yes, can you please share the updated version?
Best Regards,
Mani
apologies @Manikandan, work has me slammed. Nonetheless I have not forgotten about this. I hope to address it this weekend or perhaps sooner. I will eventually get to this.
Please @Hisma , looking forward to get the updated node.
Best Regards,
Mani
Okay, I will do my best to put some time into it tomorrow. Unfortunately my primary job has me slammed at the moment and I'm having to work weekends to compensate. I apologize. Don't worry I have not forgot!
It's working now, please test.
This was a significant refactor. I decided to migrate the code from js to ts, and got rid of the VM dependency completely and switched to secure direct execution vs the sandbox. I also created a full suite of unit tests. This means the server should be faster and more responsive, and I should be able to add features and make updates with greater ease going forward.
I still have some old dependencies to clean up, but nothing critical at this time. I will fix those soon. You can update to the latest version directly inside the pallette now.
I updated the README & release notes to highlight all the updates & rework.
From here, I would recommend that you please use my github issues page to submit any bugs or feature requests.
Thanks for your patience!
I also lost an absurd amount of time and energy trying to use the bleeding edge latest version of node-opcua on the main branch. After exhausting every single thing I could try, I simply reverted to the latest stable version and everything just magically worked. Lesson learned there.
Great stuff mate.
I was wondering if you would consider allowing issues to be posted on your fork? It doesnt look likely your great work is gonna get merged into the upstream node TBH.
Yes absolutely! I wasn't sure if this would gain any traction at all, but seeing there's people using it, and my original reason for creating the node was because there wasn't any suitable alternative to Klaus' old work, I'm happy to actively maintain this project going forward.
Folks can post any issues/feature requests there.
ahh! I assumed maybe I couldn't see it but others could. Good catch. Issues are now available.
Hello @Hisma ,
Thank you so much for resolving the issues — I truly appreciate your support.
Apologies, as I’m currently on vacation and don’t have access to test the functionality at the moment. I should be able to provide feedback in about two to three weeks.
Thanks once again for all your help!
Best Regards,
Mani
Hello @Hisma ,
Happy to share that ,the updated OPC UA server working fine.
But i am having some challenges while i am trying to configure the server with the Security Policy as Basic256Sha256 and Security method as Sign&Encrypt.
I have logged an issue in Github, Can you able to help me out here?
Thanks Again!!!
Best Regards,
Mani
