Node-red OPCUA compact Server
Hi All,
On my project I need to implement a OPCUA server.
I started by having a look at the server supplied on the node-red-contrib-opcua pallete, but then I saw that the examples I found were using the compact server from the node-red-contrib-opcua-server pallete. I went that way and I got it working, but it was a bit hard to be honest and I would like ot add some documentation to the wiki for it. When I looked a bit closer to the Wiki page a bit closer, on the right top corner it has the statement: "deprecated - very new developed by PLUS for Node-RED". I'm a bit confused... Is this the server to use or should I be using the server from the node-red-contrib-opcua pallete?
Kind Regards
Luis
