how do I turn on the led with logical AND operator?
both messages are in msg.payload.
You would have to join the messages, then apply your logic. This can be done in a function, change node or you could use boolen logic ultimate
here is an example using a change node.
[{"id":"f3bab7c9d9c50549","type":"inject","z":"fe76f7928e585317","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"table1","payload":"true","payloadType":"bool","x":120,"y":1960,"wires":[["f32fafd61d2b728c"]]},{"id":"f32fafd61d2b728c","type":"join","z":"fe76f7928e585317","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":290,"y":2040,"wires":[["0bc9af6a8ba454b7"]]},{"id":"a45d8f06f1a1a1ee","type":"inject","z":"fe76f7928e585317","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"table1","payload":"false","payloadType":"bool","x":130,"y":2000,"wires":[["f32fafd61d2b728c"]]},{"id":"de601e2d4778e239","type":"inject","z":"fe76f7928e585317","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"table2","payload":"true","payloadType":"bool","x":140,"y":2100,"wires":[["f32fafd61d2b728c"]]},{"id":"8c44f3d5af72b18d","type":"inject","z":"fe76f7928e585317","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"table2","payload":"false","payloadType":"bool","x":150,"y":2140,"wires":[["f32fafd61d2b728c"]]},{"id":"0bc9af6a8ba454b7","type":"change","z":"fe76f7928e585317","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$not(false in $$.payload.*)","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":440,"y":2040,"wires":[["048ab2e2b5799854"]]},{"id":"048ab2e2b5799854","type":"ui_led","z":"fe76f7928e585317","order":15,"group":"2d4fe667.28f8ba","width":0,"height":0,"label":"","labelPlacement":"left","labelAlignment":"left","colorForValue":[{"color":"#ff0000","value":"false","valueType":"bool"},{"color":"#008000","value":"true","valueType":"bool"}],"allowColorForValueInMessage":false,"shape":"circle","showGlow":true,"name":"","x":610,"y":2040,"wires":[]},{"id":"2d4fe667.28f8ba","type":"ui_group","name":"demo","tab":"1caa8458.b17814","order":1,"disp":true,"width":"12","collapse":false},{"id":"1caa8458.b17814","type":"ui_tab","name":"Demo","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
You have not provide enough info, so difficult to help you.
Please provide an example flow with input data, also please explain your and logic you wish to apply.
this is my flow, how to apply the and operator to the flow? thank you for your help
"id": "fe23ebf967cff990",
"type": "switch",
"z": "46af9c65977c5ac5",
"property": "payload",
"propertyType": "msg",
"rules": [
"t": "nempty"
"t": "empty"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 1270,
"y": 400,
"4b83793716b7210a"
"b995f0846e432612"
"id": "b995f0846e432612",
"type": "change",
"name": "false",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "false",
"tot": "bool"
"t": "set",
"p": "topic",
"pt": "msg",
"to": "driver_check_false",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 1410,
"y": 420,
"b694cf5ede94ab0a"
"id": "4b83793716b7210a",
"type": "change",
"name": "true",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "true",
"tot": "bool"
"t": "set",
"p": "topic",
"pt": "msg",
"to": "driver_check_true",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 1410,
"y": 380,
"b694cf5ede94ab0a"
"id": "174b93e73f95cc66",
"type": "inject",
"name": "empty",
"props": [
"p": "payload"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "",
"payloadType": "str",
"x": 1130,
"y": 420,
"fe23ebf967cff990"
"id": "2fcb49035bab89bf",
"type": "inject",
"name": "not empty",
"props": [
"p": "payload"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "not empty",
"x": 1120,
"y": 380,
"fe23ebf967cff990"
"id": "3b636428211058f5",
"type": "switch",
"rules": [
"t": "nempty"
"t": "empty"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 1270,
"y": 500,
"945d4e1fe79a8155"
"f475e721df7390f3"
"id": "f475e721df7390f3",
"type": "change",
"name": "false",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "false",
"tot": "bool"
"t": "set",
"p": "topic",
"pt": "msg",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 1410,
"y": 520,
"b694cf5ede94ab0a"
"id": "945d4e1fe79a8155",
"type": "change",
"name": "true",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "true",
"tot": "bool"
"t": "set",
"p": "topic",
"pt": "msg",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 1410,
"y": 480,
"b694cf5ede94ab0a"
"id": "5a7fdd326dc7cebb",
"type": "inject",
"name": "empty",
"props": [
"p": "payload"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "",
"x": 1130,
"y": 520,
"3b636428211058f5"
"id": "aab8d9bd798f5b09",
"type": "inject",
"props": [
"p": "payload"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"x": 1120,
"y": 480,
"3b636428211058f5"
"id": "b694cf5ede94ab0a",
"type": "BooleanLogicUltimate",
"payloadPropName": "payload",
"filtertrue": "both",
"persist": true,
"sInitializeWith": "WaitForPayload",
"triggertopic": "trigger",
"outputtriggeredby": "all",
"inputCount": 2,
"topic": "result",
"restrictinputevaluation": false,
"delayEvaluation": 0,
"x": 1570,
"y": 460,
"5f521f6e4526fbed"
"id": "5f521f6e4526fbed",
"type": "debug",
"name": "debug 9",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "false",
"statusVal": "",
"statusType": "auto",
"x": 1740,
"y": 440,
In your four change nodes you are setting msg.topic to one of two different values: "driver_check_true" and "driver_check_false".
I suspect you would be better to set it to "driver_check" in the first pair of change nodes and "vehicle_check" in the second pair.
It certainly makes no sense to include true or false in msg.topic, that's what msg.payload is carrying.
ps
You can simplify your flow if you use regular expressions in the change nodes.
[{"id":"174b93e73f95cc66","type":"inject","z":"18381fb65c388da3","name":"empty","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"str","x":190,"y":160,"wires":[["0fa90c527b69d626"]]},{"id":"2fcb49035bab89bf","type":"inject","z":"18381fb65c388da3","name":"not empty","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"not empty","payloadType":"str","x":180,"y":120,"wires":[["0fa90c527b69d626"]]},{"id":"5a7fdd326dc7cebb","type":"inject","z":"18381fb65c388da3","name":"empty","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"str","x":190,"y":260,"wires":[["2f1f1acfe396a5dd"]]},{"id":"aab8d9bd798f5b09","type":"inject","z":"18381fb65c388da3","name":"not empty","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"not empty","payloadType":"str","x":180,"y":220,"wires":[["2f1f1acfe396a5dd"]]},{"id":"b694cf5ede94ab0a","type":"BooleanLogicUltimate","z":"18381fb65c388da3","name":"","payloadPropName":"payload","filtertrue":"both","persist":true,"sInitializeWith":"WaitForPayload","triggertopic":"trigger","outputtriggeredby":"all","inputCount":2,"topic":"result","restrictinputevaluation":false,"delayEvaluation":0,"x":630,"y":200,"wires":[["5f521f6e4526fbed"],[],[]]},{"id":"5f521f6e4526fbed","type":"debug","z":"18381fb65c388da3","name":"debug 9","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":800,"y":200,"wires":[]},{"id":"2f1f1acfe396a5dd","type":"change","z":"18381fb65c388da3","name":"","rules":[{"t":"change","p":"payload","pt":"msg","from":"^.+$","fromt":"re","to":"true","tot":"bool"},{"t":"change","p":"payload","pt":"msg","from":"^$","fromt":"re","to":"false","tot":"bool"},{"t":"set","p":"topic","pt":"msg","to":"vehicle_check","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":360,"y":240,"wires":[["b694cf5ede94ab0a"]]},{"id":"0fa90c527b69d626","type":"change","z":"18381fb65c388da3","name":"","rules":[{"t":"change","p":"payload","pt":"msg","from":"^.+$","fromt":"re","to":"true","tot":"bool"},{"t":"change","p":"payload","pt":"msg","from":"^$","fromt":"re","to":"false","tot":"bool"},{"t":"set","p":"topic","pt":"msg","to":"driver_check","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":360,"y":140,"wires":[["b694cf5ede94ab0a"]]}]
Here is an example using change nodes and JSONata. the payloads are converted to true false, the messages are then joined. if either message contains a false the output is false, else output is true if both payloads are true.
[{"id":"2fcb49035bab89bf","type":"inject","z":"fe76f7928e585317","name":"not empty","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"not empty","payloadType":"str","x":140,"y":2240,"wires":[["4b83793716b7210a"]]},{"id":"4b83793716b7210a","type":"change","z":"fe76f7928e585317","name":"true/false","rules":[{"t":"set","p":"payload","pt":"msg","to":"$$.payload != \"\"","tot":"jsonata"},{"t":"set","p":"topic","pt":"msg","to":"driver_check","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":360,"y":2260,"wires":[["9124c2454fb2743b"]]},{"id":"174b93e73f95cc66","type":"inject","z":"fe76f7928e585317","name":"empty","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"str","x":150,"y":2280,"wires":[["4b83793716b7210a"]]},{"id":"9124c2454fb2743b","type":"join","z":"fe76f7928e585317","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":550,"y":2300,"wires":[["5b3330da61b5b546"]]},{"id":"945d4e1fe79a8155","type":"change","z":"fe76f7928e585317","name":"true/false","rules":[{"t":"set","p":"payload","pt":"msg","to":"$$.payload != \"\"","tot":"jsonata"},{"t":"set","p":"topic","pt":"msg","to":"vehicle_check","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":360,"y":2340,"wires":[["9124c2454fb2743b"]]},{"id":"5b3330da61b5b546","type":"change","z":"fe76f7928e585317","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$not(false in $$.payload.*)","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":720,"y":2300,"wires":[["5f521f6e4526fbed"]]},{"id":"aab8d9bd798f5b09","type":"inject","z":"fe76f7928e585317","name":"not empty","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"not empty","payloadType":"str","x":140,"y":2340,"wires":[["945d4e1fe79a8155"]]},{"id":"5a7fdd326dc7cebb","type":"inject","z":"fe76f7928e585317","name":"empty","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"str","x":150,"y":2380,"wires":[["945d4e1fe79a8155"]]},{"id":"5f521f6e4526fbed","type":"debug","z":"fe76f7928e585317","name":"debug 9","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":760,"y":2360,"wires":[]}]
thank you everyone for wanting to help, but right now both solutions haven't worked after I tried.
I tried to check the two data in MySQL, if the data exists then true, if not then false.
if both data is there then the light is on. I am attaching all my programs
"id": "46af9c65977c5ac5",
"type": "tab",
"label": "Dispense",
"disabled": false,
"info": "",
"env": []
"id": "869f63da3c96ed47",
"type": "inject",
"name": "1s",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "1",
"crontab": "",
"once": true,
"onceDelay": 0.1,
"topic": "",
"payload": "",
"payloadType": "date",
"x": 890,
"y": 1260,
"033c5b2925f89c99"
"id": "033c5b2925f89c99",
"type": "simpletime",
"mydate": true,
"myymd": true,
"myyear": true,
"mymonth": true,
"mymonthn": true,
"mydom": true,
"mydoy": true,
"myday": true,
"myhourpm": true,
"myhour": true,
"mytime": true,
"mytimes": true,
"myminute": true,
"myminutes": true,
"mysecond": true,
"mymillis": true,
"myepoch": true,
"myrawdate": true,
"mypm": true,
"x": 1070,
"y": 1260,
"690541599bda7a6b"
"id": "690541599bda7a6b",
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "mymillis",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 1280,
"y": 1260,
"d5881bd159904eac"
"id": "a8a10cc2.9d0ae",
"type": "ui_template",
"d": true,
"group": "",
"order": 0,
"width": 0,
"height": 0,
"format": "<style>\nbody.nr-dashboard-theme {\n font-size: 50px !important;\n}\n.md-toolbar-tools h1 {\n font-size: 50px !important;\n}\n</style>",
"storeOutMessages": true,
"fwdInMessages": true,
"resendOnRefresh": false,
"templateScope": "global",
"className": "",
"x": 1660,
"y": 140,
"id": "eca62c1a.40bdf8",
"d": true,
"group": "45c2b0fada35658c",
"name": "CSS: ui-table",
"order": 1,
"width": 0,
"height": 0,
"format": "<style>\n\n .tabulator{padding-left:2px;border:1px solid #000;background-color:#202529;font-size:17px}\n \n .tabulator .tabulator-header{border-bottom:0px solid #000;background-color:#202529}\n .tabulator-col-content{background-color:#202529;height:37px}\n\n .tabulator-row{min-height:31px;background-color:#181c1f}\n .tabulator-row:nth-child(2n){background-color:#202529}\n\n .tabulator-row .tabulator-cell{border-right:0px solid #888}\n .tabulator .tabulator-header .tabulator-col{border-right:0px solid #aaa}\n\n</style>",
"templateScope": "local",
"className": "",
"x": 1670,
"y": 180,
"id": "d365d02956b1c509",
"d": true,
"group": "",
"name": "top-bar logo",
"order": 1,
"width": 0,
"height": 0,
"format": "<style>\n #top-bar-logo {\n background-image: url(C:/Users/fauzi/.node-red/image/YPH-04.png);\n background-size: contain;\n background-repeat: no-repeat;\n background-position: center;\n height: 100%;\n width: 100%;\n}\n</style>\n\n<script id=\"logo-script\" type=\"text/javascript\">\nfunction build(){\n $(\"#top-bar-logo\").remove()\n var logo = $('<div />').attr(\"id\",\"top-bar-logo\");\n var topbar = $('.md-toolbar-tools');\n topbar.append(logo)\n}\nfunction checkExistence(){\n console.log($(\"#top-bar-logo\"))\n if($(\"#top-bar-logo\").length > 0){\n return\n }\n build()\n setTimeout(checkExistence,100)\n}\n\nbuild()\nsetTimeout(checkExistence,100)\n</script>\n",
"resendOnRefresh": true,
"className": "",
"x": 1470,
"y": 1220,
"id": "63cc2f30dd00919c",
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "No register",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 940,
"y": 1140,
"7bbad76d10e7bd10"
"id": "7bbad76d10e7bd10",
"type": "ui_toast",
"position": "dialog",
"displayTime": "3",
"highlight": "",
"sendall": true,
"outputs": 1,
"ok": "OK",
"cancel": "",
"raw": false,
"className": "",
"topic": "Error!",
"x": 990,
"y": 1080,
"id": "6c3631d25dd44018",
"type": "catch",
"scope": [
"3afebdb40bbf661f"
"uncaught": false,
"x": 750,
"y": 1140,
"587dde99b21ba42e",
"63cc2f30dd00919c"
"id": "587dde99b21ba42e",
"type": "debug",
"name": "debug 5",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "error.message",
"targetType": "msg",
"statusVal": "",
"x": 980,
"y": 1200,
"id": "bbe003c1fcd78cb9",
"type": "ui_text_input",
"name": "vehicle_id",
"label": "Key",
"tooltip": "",
"group": "5926a7ec1c8bca68",
"order": 1,
"width": 0,
"height": 0,
"passthru": false,
"mode": "text",
"delay": 300,
"topic": "payload",
"sendOnBlur": true,
"className": "",
"topicType": "msg",
"x": 620,
"y": 600,
"d0e3c8c83cbc646b",
"e9ac9898124acf17"
"id": "d5881bd159904eac",
"type": "ui_digital_display",
"group": "9c2005d7a47d91e9",
"order": 1,
"width": 6,
"height": 3,
"digits": 5,
"decimals": "2",
"x": 1480,
"y": 1260,
"id": "dbded81ead5dabae",
"name": "driver_id",
"label": "Key / Code *",
"tooltip": "",
"group": "3e8a11af575bd99c",
"order": 1,
"width": 0,
"height": 0,
"passthru": false,
"mode": "text",
"delay": 300,
"topic": "topic",
"sendOnBlur": true,
"className": "",
"topicType": "msg",
"x": 620,
"y": 400,
"148a11ebf32e5ecb",
"c63dd50c12e95f86"
"id": "148a11ebf32e5ecb",
"type": "function",
"name": "check drivers",
"func": "msg.topic = \"SELECT * FROM drivers WHERE driver_id='\" + msg.payload + \"';\";\n\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 810,
"y": 400,
"633d2e1dd08651ce"
"id": "633d2e1dd08651ce",
"type": "mysql",
"mydb": "31ef07c343cafec2",
"name": "drivers table",
"x": 1050,
"y": 400,
"fe23ebf967cff990",
"65999d5c3668e431"
"id": "d7f93e6b37c4ee98",
"type": "change",
"name": "send failed message",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "your key is not registered!",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 1460,
"y": 440,
"a16d73c5c97a3ebc"
"id": "a16d73c5c97a3ebc",
"type": "ui_toast",
"displayTime": "3",
"highlight": "",
"sendall": true,
"outputs": 1,
"ok": "OK",
"cancel": "",
"raw": false,
"className": "",
"topic": "Error: Key registration",
"x": 1690,
"y": 440,
"0e2641ba749541a6"
"id": "c63dd50c12e95f86",
"type": "change",
"rules": [
"t": "set",
"p": "driver_id",
"pt": "flow",
"to": "payload",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 830,
"y": 460,
"id": "013aa912d8563d25",
"type": "link out",
"name": "to clear",
"mode": "link",
"links": [
"bb5e6814ac3c9885",
"e6d2ada026c17ad8"
"x": 2060,
"y": 440,
"wires": [],
"l": true
"id": "bb5e6814ac3c9885",
"type": "link in",
"name": "from clear",
"links": [
"013aa912d8563d25"
"x": 440,
"y": 400,
"dbded81ead5dabae"
"l": true
"id": "0e2641ba749541a6",
"type": "change",
"name": "clear data",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 1880,
"y": 440,
"013aa912d8563d25"
"id": "d0e3c8c83cbc646b",
"type": "function",
"func": "msg.topic = \"SELECT * FROM vehicles WHERE vehicle_id='\" + msg.payload + \"';\";\n\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 810,
"y": 600,
"a537d7486545c859"
"id": "a537d7486545c859",
"type": "mysql",
"name": "vehicles table",
"x": 1060,
"y": 600,
"5cce97c399e78739",
"7ef143da77cde04b"
"id": "5cce97c399e78739",
"type": "switch",
"rules": [
"t": "nempty"
"t": "empty"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 1250,
"y": 600,
"fc5daa19e538282e"
"id": "fc5daa19e538282e",
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 1460,
"y": 640,
"de990773afe19696"
"id": "e9ac9898124acf17",
"type": "change",
"rules": [
"t": "set",
"p": "vehicle_id",
"pt": "flow",
"to": "payload",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 830,
"y": 660,
"id": "e274b0bfd4bc3c52",
"type": "link out",
"name": "to clear",
"mode": "link",
"links": [
"92f099a14735f5f5",
"e5a70d58744f2c47"
"x": 2080,
"y": 640,
"wires": [],
"l": true
"id": "92f099a14735f5f5",
"type": "link in",
"links": [
"e274b0bfd4bc3c52"
"x": 440,
"y": 600,
"bbe003c1fcd78cb9"
"l": true
"id": "77cdf4aae53b687e",
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 1880,
"y": 640,
"e274b0bfd4bc3c52"
"id": "600873210303735c",
"name": "Cancel",
"order": 4,
"width": 4,
"height": 1,
"format": "\n<md-button class=\"vibrate filled touched smallfont rounded\" style=\"background-color:#0094CE\" ng-click=\"send({payload: 'Cancel'})\"> \n Cancel<br/>\n</md-button> \n\n",
"fwdInMessages": false,
"className": "",
"x": 800,
"y": 740,
"d908d2c3e3d1c022"
"id": "d908d2c3e3d1c022",
"type": "link out",
"name": "to clear all",
"mode": "link",
"links": [
"bfa2d52e1a6c0d57",
"648797d0a55fc31d"
"x": 970,
"y": 740,
"wires": [],
"l": true
"id": "bfa2d52e1a6c0d57",
"type": "link in",
"name": "from clear all",
"links": [
"d908d2c3e3d1c022"
"x": 1690,
"y": 480,
"0e2641ba749541a6"
"l": true
"id": "648797d0a55fc31d",
"type": "link in",
"links": [
"d908d2c3e3d1c022"
"x": 1690,
"y": 680,
"77cdf4aae53b687e"
"l": true
"id": "de990773afe19696",
"type": "ui_toast",
"displayTime": "3",
"highlight": "",
"sendall": true,
"outputs": 1,
"ok": "OK",
"cancel": "",
"raw": false,
"className": "",
"x": 1690,
"y": 640,
"77cdf4aae53b687e"
"id": "4ca2a42112bffdb6",
"type": "ui_led",
"order": 2,
"width": 0,
"height": 0,
"label": "",
"labelPlacement": "left",
"labelAlignment": "left",
"colorForValue": [
"color": "#ff0000",
"value": "false",
"valueType": "bool"
"color": "#008000",
"value": "true",
"valueType": "bool"
"allowColorForValueInMessage": false,
"shape": "circle",
"showGlow": true,
"x": 2050,
"y": 580,
"id": "0015e288da51c85f",
"type": "inject",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "table2",
"payload": "false",
"payloadType": "bool",
"x": 1390,
"y": 1040,
"type": "switch",
"rules": [
"t": "nempty"
"t": "empty"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 1250,
"y": 400,
"d7f93e6b37c4ee98"
"id": "3a9ae8ae55fcce89",
"type": "change",
"name": "true",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "true",
"tot": "bool"
"t": "set",
"p": "topic",
"pt": "msg",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 1410,
"y": 360,
"a3173db41f89d858"
"id": "2ea4e2d383f2238c",
"type": "change",
"name": "false",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "false",
"tot": "bool"
"t": "set",
"p": "topic",
"pt": "msg",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 1410,
"y": 400,
"a3173db41f89d858"
"id": "9a96fa485efd39b8",
"type": "change",
"name": "true",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "true",
"tot": "bool"
"t": "set",
"p": "topic",
"pt": "msg",
"to": "vehicle_check_true",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 1410,
"y": 560,
"id": "d16efd8d4b33d498",
"type": "change",
"name": "false",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "false",
"tot": "bool"
"t": "set",
"p": "topic",
"pt": "msg",
"to": "vehicle_check_false",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 1410,
"y": 600,
"id": "a3173db41f89d858",
"type": "debug",
"name": "debug 11",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 1660,
"y": 360,
"id": "2566013ead2f6f5f",
"persist": true,
"inputCount": 2,
"topic": "result",
"x": 1670,
"y": 800,
"fcae1fcc26b45b8f",
"4ca2a42112bffdb6"
"id": "fcae1fcc26b45b8f",
"type": "debug",
"name": "debug 14",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 1840,
"y": 800,
"id": "7ef143da77cde04b",
"type": "change",
"rules": [
"t": "change",
"p": "payload",
"pt": "msg",
"from": "^.+$",
"fromt": "re",
"to": "true",
"tot": "bool"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "^$",
"fromt": "re",
"to": "false",
"tot": "bool"
"t": "set",
"p": "topic",
"pt": "msg",
"to": "vehicle_check",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 1480,
"y": 720,
"2566013ead2f6f5f"
"id": "65999d5c3668e431",
"type": "change",
"rules": [
"t": "change",
"p": "payload",
"pt": "msg",
"from": "^.+$",
"fromt": "re",
"to": "true",
"tot": "bool"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "^$",
"fromt": "re",
"to": "false",
"tot": "bool"
"t": "set",
"p": "topic",
"pt": "msg",
"to": "driver_check",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 1600,
"y": 540,
"2566013ead2f6f5f"
"id": "45c2b0fada35658c",
"type": "ui_group",
"name": "Transactions",
"tab": "e11aa43fd19026d6",
"order": 1,
"disp": true,
"width": "21",
"collapse": false,
"className": ""
"id": "5926a7ec1c8bca68",
"type": "ui_group",
"name": "Enter Vehicles Key",
"tab": "8de2e50a0e16ee3b",
"order": 2,
"disp": true,
"width": 4,
"collapse": false,
"className": ""
"id": "9c2005d7a47d91e9",
"type": "ui_group",
"name": "Flowmeter",
"order": 3,
"disp": true,
"width": "6",
"collapse": false,
"className": ""
"id": "3e8a11af575bd99c",
"type": "ui_group",
"name": "Enter Drivers Key",
"order": 1,
"disp": true,
"width": 4,
"collapse": false,
"className": ""
"id": "31ef07c343cafec2",
"type": "MySQLdatabase",
"host": "127.0.0.1",
"port": "3306",
"db": "mydatabase",
"tz": "",
"charset": "UTF8"
"id": "e11aa43fd19026d6",
"type": "ui_tab",
"icon": "assignment_turned_in",
"order": 2,
"disabled": false,
"hidden": false
"id": "8de2e50a0e16ee3b",
"type": "ui_tab",
"name": "Dispense",
"icon": "local_gas_station",
"order": 1,
"disabled": false,
"hidden": false
Put a debug node after each database node and after each "change:3rules" node, set to show the complete message.
What do they show 1) when both driver and vehicle id are valid and 2) when one of them is invalid?
What does the status message under the boolean logic node say in each case?
Instead of putting this logic in node-red, I would write a query that outputs the value you need (ie. put the logic in mysql, not node-red)
