Mostly just small bug fixes - but added a Site option to let swipe open and close the menu rather than actually move tabs (or do nothing).
I have also disabled mouse swipe so that text fields can now be copied/cut correctly - now touch events only.
Also a fix to allow exporting spacers correctly - but sadly requires a fix in core so that will need Node-RED v2 (coming soon)
Enhancements
- Add site option to allow swipe to open/close side menu, instead of moving tabs.
Fixes
- Fix dropdown to allow use of id property if selecting an object. Issue #707
- Activate deploy button on any change to site options (even a non-change)
- Fix spacer node to be on tab so can be exported as part of the tab (needs NRv2)
- Try to handle disabled groups and tabs more cleanly.
- Disable mouse for swipe actions - only use touch events.
As usual please ensure you really flush the client browser cache to get the latest changes.
