[ANNOUNCE] node-red-contrib-covid19
First of all i want to thank @BartButenaers for helping me understand the 'functionality of custom nodes'.
After couple of days of writing code and debuginig i managed to create a first beta version (some of functionality was ejected, as i couldn`t resolve some errors).
You can check the code @ github
Had some problems when uploading the package to npm regarding of ` Package name triggered spam detection' so i emailed the support and they allowed me to upload.
This is a simple node to gather statistics regarding of COIVD-19 (Corona) virus cases.
It was just a small project for me, after someone on facebook left me a comment with github page on COVID19 JSON file.
THE RESULTS MAY NOT BE 100% ACCURATE
Morning Vukmirovic,
I must admit that I am really impressed. When I compare your Node-RED knowledge level today and a few weeks ago, it is amazing to see how much you have learned from experimenting and reading code from other people. :+1: :+1: :+1: :+1:
Nice to have you in the community, and keep up the good work!
P.S. Probably you already know, but just in case: if you ever publish your final version (after your beta's), don't forget to add the "node-red" keyword in your package.json file. Otherwise it will not appear in the Node-RED palette. But indeed for a beta version you don't want it to appear in the palette.
Bart
If you ever manage to build up some partnership with @BartButenaers, all the best and a bit more will be squeezed out from you but in the very nice and friendly way.
To improve your powers and discover your hidden skills, work with Bart
Well, actually I wasnt very happy myself with the code I wrote . Especially where I needed to fetch the JSON file two times in the js file (variable result was returning undefined couldn't figure out why as I declared it globally and literally made 20+ changes in the code to try to fetch only on node input, but I didn`t manage to do it). And decide to push it to npm.js but not for node-red
And the server for pulling statistics is not very reliable as it gets offline several times a day.
And, of course, any recommendation for improvement of the node is needed.
Damn, busted :rofl: :joy: :rofl:
I understand that you call it as soon as an input message arrives, but why do you need to get it when your node is started? Perhaps you can explain this a bit more in details, so we can help you with it ...
Version 1.1.0 is available on NPM
I fixed the issue of using msg,covid19 and changed it to just msg.covid
And the node is not running fetch on deployment anymore :smiley:
And I also fixed some errors and status messages.
Most people seem to be using the data published by Johns Hopkins which comes from the original WHO data. I've used that myself in an example flow and in a spreadsheet I'm using as a test to myself of using Excel PowerQuery, pivot tables and charts. I combined that with standard population data so that I could do things like normalise the number of cases as a % of population. Some useful mental exercises more than really taking the numbers too seriously since there are far too many variables for the numbers to be all that accurate.
Hi, thank's...I want to try your node...for my dashboard!
Very goood
Great :smiley: if you have any issues or anything you can submit them at Github
Version 2.0.0 is on npmjs
-added two new nodes
-the first node (COVID-19) is renamed (may cause a crash in the flow)
  • All of the nodes are located under COVID19 category
