[ANNOUNCE] node-red-contrib-letsencrypt : beta version
So, I thought it was an opportunity to change domain registrars, so... I cancelled Ionos, and transferred my domain to 'NameCheap' because they are listed as having an api.
Wrong!! well sort of. When I tried to access their api, I got this message -
So back to the drawing board!
If you redirect the nameservers to Cloudflare from your registrar's own servers, you will get everything you need. I still do that with my .uk domains as I can't yet transfer those completely into Cloudflare.
Then it really doesn't matter which registrar you use. I use TSOhost for mine (used to be Daily but they were taken over).
Mine is also a .uk domain, and can't transfer it to Cloudflare either, but that's good news Julian. Once Bart decides upon a permanent contrib name I'll give it a try in a Oracle VM node-RED instance using Cloudflare.
I understand that very shortly, Cloudflare are starting to sell domains directly, instead of just accepting transfers. That should shake the market up :smile:
I liked Julian's proposal, but seems somebody already used node-red-contrib-lets-encrypt ...
So the new name for mine is now node-red-contrib-letsencrypt.
Be aware that I didn't have time yet to test all the DNS providers. So there might be some bugs ...
Just wish they would do UK domains too. But I have some non-UK domains transferred to them.
...you're missing a "t" in that new link -> "https://github.com/bartbutenaers/node-red-contrib-letsencrypt" :wink:
Thanks!! It is updated now. Otherwise I could have called my node now the node-red-contrib-error-404 :shushing_face:
Installing in a Oracle Linux VM instance...
certs
node-RED log shows - Cannot find Acme Client node with id = 2e9616dc.9ec6e2
Node-RED version: v1.0.6
Node.js version: v10.20.1
Linux 4.14
Morning Paul,
Seemed it needed to be deployed before calling this server side functionality. However that is only required to create a subscriber account, not for a simple hash. It is now fixed on Github.
Yes that is now fixed.
However, I get a similar error when trying to Create Acme subscriber account. I get the pop-up asking to agree the terms, and when I agree, the node-RED log reports -
Even when you have deployed your node first (as described in the popup)?
Yes. But I've found the problem. There was a format error in the Domain array (missing quote).
Corrected and now successfully Acme account created.
And you don't see any visual indication of such an error?
I think it would be more user friendly to subscribe with the info on the screen, instead of with the deployed data?
Still having problems I'm afraid. When I request a certificate, I get;
acmeerror
and in the node-red log;
21 May 08:56:02 - [info] [aedes broker:41b47ed.32a568] Binding aedes mqtt server on port: 1883
21 May 08:56:02 - [info] Server now running at http://127.0.0.1:2086/
21 May 08:56:02 - [info] [mqtt-broker:9e0fbc51.f0a3e] Connected to broker: mqtt://140.238.65.67:1883
21 May 08:56:11 - [warn] [acme-client:Certificate Management] Acme warning message = dns-01 challenge's `propagationDelay` not set, defaulting to 5000ms status =
21 May 08:56:12 - [error] [acme-client:Certificate Management] Error in CREATE_CERTIFICATE : Error: HTTPError: Response code 400 (Bad Request)
It's worth pointing out that I don't already have any certificates in my server. Do I need to create dummy ones?
The domain being used is a sub domain.
No when private key setting is "use or create private key" then everything should be setup automatically...
Will need to debug this. Is there a simple znd quick way for me to setup and test a cloudflare connection tonight? Would be nice if I don't have to digg through 20 manuals... Or send me a private message if you like ... Thanks!
Yes, sure. I'll PM you the necessary later today.
Is anyone successfully using this with Cloudflare. The DNS challenge is failing for me.
API token or Key?
Cloudflare API token, setup as per https://certbot-dns-cloudflare.readthedocs.io/en/stable/
There are access issues with the Token - what error do you get? I had to do something really odd to get it through the security model but I can't find what I did. They changed something as is stopped working. Basically you need to give the token access to everything.
