[ANNOUNCE] Node-RED Desktop v0.9.1 Released
Hi all,
I have released Node-RED Desktop v0.9.1 .
Version 0.9.x bundles Node generator and npm commands(npm link and npm install).
These will help you ease to create a custom node on GUI.
How to create a custom node
  1. On deployed flow, select a function node, and [Tools]-[Generate a custom node].
  2. If nessesary, update created files,
  3. [Tools]-[Install a local node]
If you have interested in Node-RED Desktop, Please try it.
Regards,
sakazuki
What is Node-RED Desktop
Node-RED Desktop is a desktop application of Node-RED for windows/mac.
You can
  • easily setup Node-RED on your desktop.
    • with one click installer and auto updater
  • quickly create and discard a flow many times.
    • with standard file menu.
  • easily publish the public HTTP endpoint and integrate with cloud services.
    • with embeded ngrok.
  • easily create a custom node
    • with node-red-nodegen, and bundled npm commands
And also,
You can use almost all powerful and useful Node-RED features
When running your Desktop version - I notice the port that it is running on changes each time I run it
Can this be made a fixed port number?
You can fix the port number with environment variables.
ex. NRD_LISTEN_PORT=1880
Ref https://github.com/sakazuki/node-red-desktop/wiki
That is amazing.
Good to know it can be fixed :slight_smile:
But my main use case for Desktop Node-RED is in a school where setting an environment variable would be difficult to do.
Could it be modified to use a config text file in the program folder?
Or in settings?
Ok,
Since there are occasional requests to fix the port, I make it configurable in settings.
Maybe in next release.
Regards,
