Hello Guys,
Im looking for a way to trigger a Node-Red flow when a specific notification is triggered on a remote Apple Mac via the native MacOS notification platform.
I can't figure out how best to do this, this Mac is being used as a headless server so isn't monitored actively, I'm hoping to trigger a flow that will issue a push notification via my Home Assistant instance when such an event is triggered.
Any ideas?
The notification is produced based on some result, looks like creation of an mkv. Can you not monitor the output directory of that mkv instead ? There is a "watch" node, that can monitor directories/files. I don't think you can capture that notification, unless it is being logged somewhere in a log file.
Hmm, not looking good. I did a search which turned up nothing positive, then I tried the new Bing search GPT AI function:
Ah, but ChatGPT seems to be more hopeful. so maybe try this out:
To trigger a webhook when a notification is shown on a Mac, you can use a combination of native Mac tools and a third-party app. Here's a general outline of the steps involved:
- Install the "terminal-notifier" package using Homebrew. To install Homebrew, open a Terminal window and run the following command:
/bin/bash -c "$(curl -fsSL https://raw.githubusercontent.com/Homebrew/install/HEAD/install.sh)"Then run the following command to install terminal-notifier:brew install terminal-notifier
- Write a script that will listen for incoming notifications and trigger a webhook when a notification is shown. Here's an example script that uses the "jq" command-line tool to extract the notification title and message, and then uses the "curl" command to send a webhook:
#!/bin/bash
# Listen for incoming notifications
terminal-notifier -group mygroup -title '' -message '' -sender com.apple.Terminal -json |
# Extract the notification title and message
jq -r '.["title"] + "\n" + .["message"]' |
# Send a webhook using curl
xargs -I{} curl -X POST -H "Content-Type: application/json" -d '{"title": "Notification Triggered", "message": "{}"}' https://your-webhook-url.com
- Save the script as a file, for example "trigger-webhook.sh".
- Make the script executable by running the following command in the Terminal:
chmod +x trigger-webhook.sh
- Set up a "Launch Agent" to run the script in the background whenever the system is running. Here's an example Launch Agent file that you can modify to your needs:
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>Label</key>
<string>com.yourdomain.trigger-webhook</string>
<key>ProgramArguments</key>
<array>
<string>/path/to/trigger-webhook.sh</string>
</array>
<key>RunAtLoad</key>
<true/>
</dict>
</plist>
- Save the Launch Agent file as "com.yourdomain.trigger-webhook.plist" in the directory "~/Library/LaunchAgents/".
- Load the Launch Agent by running the following command in the Terminal:
launchctl load ~/Library/LaunchAgents/com.yourdomain.trigger-webhook.plist
That's it! Your Mac will now listen for incoming notifications and trigger a webhook whenever a notification is shown. You can modify the script to extract different parts of the notification, or to trigger different webhooks based on the notification content.
I don't see how this would work. OP wants to trigger a flow based on the notification he receives, not to create one:
terminal-notifier: Send User Notifications on macOS from the command-line.
But it is marked as solved, I am intrigued.
In Node-RED, you create a web endpoint (a webhook) that is the trigger for a flow.
On the mac you use the 3rd-party tool for watch for the notification and trigger a web GET to that endpoint.
That's it. Job done. (Assuming it works, I didn't test it because I really can't be bothered to dig out my Macbook Pro, wait for all its updates, install node.js and node-red and the 3rd-party app, work out how to create a repeatable notification, write the apple script and node-red flow!!
But hey, done once, it should work forever.
Sure, except that is not what it is doing.
"watch" for the notification - needs to be extracted/triggered from somewhere, log, database etc (if it is even logged), but it is not the terminal.
Isn't it doing what it says it is doing?
Sure, for stuff created/triggered in the terminal…
