Anyone else's Alexa node not initialising?
[edit] Decided to check on github repo and someone else has the same issue
I've been using the cookie method, which is still working.
Yes, just updated and issue went away.
I am seemingly up to date already - what version are you using?
5.0.21 updated about 5 hours ago.
I just updated and restart node-red then injected the previous saved cookie into the Init node set to initialise. I did not have to do any auth through the proxy port 3456. as i store the auth in context after a successful initialisation .
node-red-contrib-alexa-remote2-applestrudel has been updated to 5.0.22 to incorporate upstream changes and it's now working again for me
Hi all,
Well I delayed trying to update the node-red-contrib-alexa-remote2-applestrudel to 5.0.22
So I am still running an older version 5.0.20
It's 7 hours since I noticed that Alexa was not working, but now it is without updating ?
For the moment I will leave it as is, and see what happens, perhaps amazon was doing some work on the server side ?
