Anyone had a play with good-i-deer/node-red-contrib-vision-ai?
Inspired by some other discussions, I took the plunge and replaced my Ring Doorbell.
I came across these nodes the other day when looking for alternatives to node-red-contrib-facial-recognition
With the above node I couldn't seem to get very good recognition scores, however this one from Samsung Automation Studio Team does seem to be a lot more accurate with the detections.
It's not the easiest to figure out as the documentation is a bit thin on the ground, but well worth looking at as an alterative.
I'm creating some flows around the nodes to pre enrol directories of images and then recognise faces captured from my reolink doorbell camera.
Performance wise it takes around 2 seconds from image injection to matched name on my busy Pi4.
Tested the object detection node on a RPi5 and it seems to do a very good job and pretty fast on single shots. For some of my images I had to change the model to "s" to get a hit but those images are tricky
Seems to run pretty fast, for single shots and frontal views as from a doorbell camera I would assume you will get a very accurate result w face recognition. For object detection it worked fine detecting persons
For real time video streaming I expect you need a very powerful computer using high end NVIDIA graphics or similar. Anyway they have managed to implement a nice set of nodes w YOLO v8
Any opportunity to show off with your RPi5 Walter :rofl:
I haven't really looked into the backend much, but I see it's not TensorFlow, so not sure what hardware acceleration might be possible.
But its a good fit for my "needs" (no one really needs this :wink: ) to identify people from the doorbell camera.
I may have to get NR installed on a Pi5 now :thinking: though it is fast enough on Pi4 to be fair.
Sure I can do. What do you have in mind?
I would expect the RPi5 to be some 5 times faster than the RPi4
It is not using TF, it is using the latest and more reliable & accurate YOLO, v8. YOLO is more resource hungry but also supports GPU. But I do not now if it does support it on the RPi and with these nodes (I'll ask on Github)
I have not used the face detection but the object detection is rather impressive and accurate I think
Thanks for the offer, though it was actually meant as a joke (bragging about your RPi5 whenever you post) :wink:
Apologies my British humour may not translate well.
If I get time I will setup MY RPi5 with NR test it :rofl:
Darn it, I kind of want a RPi5 16GB now! Even though I don't actually NEED one and its power consumption seems to be about the same as the old laptop I'm using.
And they are in stock.
So I just setup the same flow on a Pi5, to test against a Pi4 doing the enrolling of faces with the above nodes.
Pi4 time to complete =160 sec vs Pi5 time to complete =38 sec
Other tests with single face recognition using same data averages 4 times faster.
Impressive :grinning: though not very scientific at the moment as my Pi4 is running other flows.
As its my live Pi4 I cannot really stop other flows and services for a true comparison.
Which of the models are you using (if selectable when using face recognition)?
It's not selectable in the node, but looking at the source I believe its yolov8n-face.onnx
If "s" and "m" models are available somewhere, maybe the accuracy can be improved (hacking the source if needed). But it might be it is good enough. I have not used face recognition yet in my application but is cool, especially if you have a doorbell camera
Other pre-trained models can be found here -
GitHub - lindevs/yolov8-face: Pre-trained YOLOv8-Face models.
It's the ONNX version that is used by this node. I have tried the larger YOLOv8s-Face and it works OK as a drop in replacement, thought unsurprisingly it takes a bit longer to run.
Sill experimenting, but the nano version seems to work fine anyway, so probably not worth using the larger model.
I have been working on my flow for these nodes, and trying to improve the speed / efficiency of the processing, see Node-red-node-annotate-image - using canvas
It's looking like a good alternative to node-red-contrib-facial-recognition certainly on my Pi5 its taking around 0.5 seconds to provide a name from CCTV still image.
I will keep tweaking and share the flow when I'm happy with it :wink:
I did some tests with it for object detection. Since I run most of such stuff in Python outside of NR so I have several rather powerful scripts that handles many related tasks for this type of applications. All of them also did run the engine for the detection, TFLite, YOLO
So what I did was to modify one of those scripts and instead via MQTT "pipe" images to the node in NR and then back for further handling
From functionality point of view, it works. But for my application is becomes a bit too slow. If you just send a few images or single shots, the time for detection is the same as for you, around 0,5 sec. But I do push many images rapidly so the thing get's "a bit busy" and the time goes up close to 2 seconds. But it works, it doesn't crash
I'm sort of tempted, at least a bit, to try this little flow (as seen below) on a faster thing and see if it works faster there. I do have some NVIDIA Jetson Nano's but I think, unfortunately, it will not use the GPU's anyway
It does support hardware acceleration,
Also there is a fork of that node where someone has added that as an option.
