ApexChart- How to delete shades
Hello friends, I hope you are doing well!
I would appreciate it if help me to figure out how to remove shades out of my curves!
Actually, my problem is when I inject data into chart the curves aren't clean! I mean I want to see curves without any shades. I read the documents here but I couldn't find a related parameter for adding/removing shades!
        "id": "ba30230bdd7b910f",
        "type": "ui_template",
        "z": "c0c06963c97bbd82",
        "group": "7b79c772fbaab385",
        "order": 1,
        "width": 20,
        "height": 13,
        "format": "<script src=\"https://cdn.jsdelivr.net/npm/apexcharts\"></script>\n<div id=\"chart\"></div>\n\n<script>\n  (function(scope) {\n  scope.$watch('msg', function(msg) {\n    if (msg) {\n      // Do something when msg arrives\n     var options = {\n          series: msg.payload,\n          chart: {\n          type: 'line',\n          stacked: false,\n          height: 500,\n          zoom: {\n            type: 'x',\n            enabled: true,\n            autoScaleYaxis: true\n          },\n        //  toolbar: {\n        //    autoSelected: 'zoom'\n        //  }\n        },\n        stroke: {\n        curve: 'smooth',\n        }\n        ,\n         dataLabels: {\n           enabled: false\n         },\n         markers: {\n           size: 0,\n         },\n        theme: {\n        mode: 'dark'    // dark , light\n        },\n        title: {\n          text: 'Historic data',\n          align: 'left'\n        },\n         //fill: {\n         //  type: 'gradient',\n         //  gradient: {\n         //    shadeIntensity: 0,\n         //    inverseColors: false,\n         //    opacityFrom: 0.5,\n         //    opacityTo: 0,\n         //    stops: [0, 90, 100]\n         //  },\n         //},\n         yaxis: {\n           labels: {\n             formatter: function (val) {\n               return val;\n             },\n           },\n          // title: {\n          //   text: 'Price'\n          // },\n         },\n        xaxis: {\n          type: 'datetime',\n        },\n         tooltip: {\n           shared: false,\n           y: {\n             formatter: function (val) {\n               return (val / 1000000).toFixed(0)\n             }\n           }\n         }\n        };\n\nsetTimeout( ()=> {\n\n    if(scope.chart){\n      scope.chart.updateOptions(options)\n    }\n    else {\n      scope.chart = new ApexCharts(document.querySelector(\"#chart\"), options);\n      scope.chart.render();\n    }\n    \n}, 1000)\n\n    }\n  });\n})(scope);\n</script>",
        "storeOutMessages": false,
        "fwdInMessages": false,
        "resendOnRefresh": false,
        "templateScope": "local",
        "className": "",
        "x": 660,
        "y": 1080,
        "id": "331c581fae67856e",
        "type": "function",
        "name": "Chart | Apex",
        "func": "var msg1;\nvar msg2;\nvar apex_chart = [];\n\n\n\nvar chart = [{\n    \"series\":[],\n    \"labels\":[msg.filename],\n    \"data\": []\n}];\n\n\n\nlet columns = 0;\n\nfor(var series in msg.payload[0]) {\n    if(series!==\"Timestamp\") {\n        chart[0].series.push(series);\n        chart[0].data.push([]);\n        columns++;\n    }\n}\n\n\nfor (var j=0; j<msg.payload.length; j++) {\n   for(var i=0;i<columns;i++) {\n       chart[0].data[i].push({\"x\":msg.payload[j].Timestamp, \"y\":msg.payload[j][chart[0].series[i]]});\n   } \n}\n\nfor (var k = 0; k < chart[0].series.length; k++) {\n    apex_chart.push({\n        name: chart[0].series[k],\n        data: chart[0].data[k]\n    })\n}\nmsg1 = { payload: chart }\nmsg2 = { payload: apex_chart }\n\n\n//msg.payload =  chart ;\n\n\n\n\n\nreturn [msg1,msg2];\n\n\n\n\n\n\n\n\n\n\n\n\n\n",
        "outputs": 2,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 410,
        "y": 1040,
                "fc4bf11b088a905d"
                "207d795590aa3f4c",
                "ba30230bdd7b910f"
        "id": "fc4bf11b088a905d",
        "type": "debug",
        "name": "debug 343",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "payload",
        "targetType": "msg",
        "statusVal": "",
        "statusType": "auto",
        "x": 605,
        "y": 1000,
        "wires": [],
        "l": false
        "id": "207d795590aa3f4c",
        "type": "debug",
        "name": "debug 346",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 605,
        "y": 1040,
        "wires": [],
        "l": false
        "id": "29ca60946c853c61",
        "type": "inject",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "[{\"Timestamp\":\"11/15/2023 9:18:06 AM\",\"Tensione fase R\":68,\"Tensione fase S\":229,\"Energia rigenerata totale\":304},{\"Timestamp\":\"11/15/2023 9:18:16 AM\",\"Tensione fase R\":252,\"Tensione fase S\":84,\"Energia rigenerata totale\":198},{\"Timestamp\":\"11/15/2023 9:18:26 AM\",\"Tensione fase R\":324,\"Tensione fase S\":154,\"Energia rigenerata totale\":190},{\"Timestamp\":\"11/15/2023 9:18:36 AM\",\"Tensione fase R\":47,\"Tensione fase S\":48,\"Energia rigenerata totale\":307},{\"Timestamp\":\"11/15/2023 9:18:46 AM\",\"Tensione fase R\":16,\"Tensione fase S\":37,\"Energia rigenerata totale\":-25},{\"Timestamp\":\"11/15/2023 9:18:56 AM\",\"Tensione fase R\":310,\"Tensione fase S\":-34,\"Energia rigenerata totale\":-31},{\"Timestamp\":\"11/15/2023 9:19:06 AM\",\"Tensione fase R\":166,\"Tensione fase S\":279,\"Energia rigenerata totale\":-35},{\"Timestamp\":\"11/15/2023 9:19:16 AM\",\"Tensione fase R\":196,\"Tensione fase S\":-19,\"Energia rigenerata totale\":63},{\"Timestamp\":\"11/15/2023 9:19:26 AM\",\"Tensione fase R\":-47,\"Tensione fase S\":7,\"Energia rigenerata totale\":197},{\"Timestamp\":\"11/15/2023 9:19:36 AM\",\"Tensione fase R\":326,\"Tensione fase S\":98,\"Energia rigenerata totale\":10},{\"Timestamp\":\"11/15/2023 9:19:46 AM\",\"Tensione fase R\":306,\"Tensione fase S\":308,\"Energia rigenerata totale\":-6},{\"Timestamp\":\"11/15/2023 9:19:56 AM\",\"Tensione fase R\":269,\"Tensione fase S\":36,\"Energia rigenerata totale\":-1},{\"Timestamp\":\"11/15/2023 9:20:06 AM\",\"Tensione fase R\":93,\"Tensione fase S\":255,\"Energia rigenerata totale\":206}]",
        "payloadType": "json",
        "x": 170,
        "y": 1060,
                "331c581fae67856e"
        "id": "7b79c772fbaab385",
        "type": "ui_group",
        "name": "Zoomable time series",
        "tab": "968b45b75eb8747a",
        "order": 5,
        "disp": true,
        "width": "20",
        "collapse": true,
        "className": ""
        "id": "968b45b75eb8747a",
        "type": "ui_tab",
        "name": "Training",
        "icon": "dashboard",
        "order": 19,
        "disabled": false,
        "hidden": false
Thanks in advance for your helps!
Did you try searching with google?
Yes indeed! I tried this
chart: {
    dropShadow: {
        enabled: false,
        enabledOnSeries: undefined,
        top: 0,
        left: 0,
        blur: 3,
        color: '#000',
        opacity: 0.35
but doesn't work!
This has nothing related to the apex charts config but the dashboard CSS does have a bit nasty rule for ui_templates and SVG path elements.
But there is always a solution..
For ui_template node add a CSS class
And then write a bit of CSS using another ui_template node
Dear @hotNipi I really appreciate it. now it looks good :star_struck:
