Hi!
I have a notification system that notifies me via google assistant speakers when particulate matter (PM) is above a certain threshold. Works well sending the notification to my speakers BUT I als would like for it to be sent as a message on my cell phone (with the companion app), but keep getting an API error when a notification is sent. Please see flow below, along with call service node setup.
Please let me know if you require more informatoin here.
E1cid
26 February 2022 17:33
2
I do not use HA, you might get a better answer on the HA forum.
But you would need to send the service some data, at least a title and message.
Try pasting this in where it says data
"title": "A Title",
"message": "A Message"
If that works, then you can feed a payload into the node and set data to msg.payload, or what ever properties you want to use.
The mobileapp notify platform accepts the standard title, message and target parameters used by the notify platform. The mobile\app notify platform supports targets as services. As long as you granted notifications permissions during setup, you will...
@E1cid thanks very much! By placing the json text in the data box, and injecting time stamp, it works i get the message I set to my phone app.
How do I now feed the existing payload into the node and set data to msg.payload?
Here is the function node before the call node
E1cid
26 February 2022 20:55
4
I can not work with text in an image,
but your function node would be something like this
msg.payload = {
"title": msg.topic,
"message": msg.some_property_name + " " + msg.some_other_property
Then in data you would select msg and type in payload.
E1cid:
msg.payload,
thanks very much! The function node is as you wrote it, and then I changed the call service node this below
I was not able to find "msg" so i just wrote what what shown in the photo.
E1cid
26 February 2022 21:04
6
You have not selected msg.
where it says {} click the chevron to the left, select msg. Then type payload.
You will need to add your own properties to the function, the one's i put there are dummy ones to show you how to construct your own. As i said images do not help me help you you need to pastes code.
I don't have msg when select the chevron to the left. please see here:
here is my function node in code
msg.payload = msg.topic + " Particulate Matter levels are at " + msg.PM25EOut_reading + " ug/m3";
E1cid
26 February 2022 21:36
8
Then pick j expression and type payload.
You have to then set the function as i showed
msg.payload = {
"title": "some_title",
"message": msg.topic + " Particulate Matter levels are at " + msg.PM25EOut_reading + " ug/m3";
[edit]
Or you can select J expression (JSONata) and enter
"title": "A Title",
"message": $$.topic & " Particulate Matter levels are at " & $$.PM25EOut_reading & " ug/m3"
And not use the function node at all.
@E1cid thanks for your help !!
