Including timestamp in a call service to Notify
First post here - I hope I get this right!
I'm running Node Red v2.2.0 on Home Assistant and when certain events happen in NR I want to use the call service function to send a notification to my mobile. This bit I have working.
BUT :slight_smile:
I want to timestamp the message being sent out by the notify call. From my googling I have found that it may be possible by calling a node red function (see here) but I don't yet understand how I can include the output of this function into the call service option.
Here (See attachment) is the detail of my call service section. Can I somehow include the date and time in the output to my mobile?
You can do that directly in the call service node with the JSONata expression
{"message": "GR lamp ON " & $moment().tz("Europe/London").format("DD-MM-yyyy HH:mm:ss")}
[edit] you can also add msg vaiables the same way
eg.
{"message": "GR lamp ON " & $$.payload}
should add the contents of msg.payload.
Wow ! Thank you! I'm off to play....sorry mean test!
Ta
Thank you - it worked first time :slight_smile:
I can already send a normal text string by email.
I have concatenated a string message in a function. And the debug screen shows a correct string
Now I want to send the payload of the function by email
I don't find the correct syntax to send this message. This does not works
"title": "Temperaturen Herman",
"message": "{{msg.payload}}"
Nor this
"message": "Temperaturen zijn:", $$.payload
