Ideally, I'd like to set the HTML elements to be readonly (and style with CSS, so it's apparent), if the credentials are supplied via environment variables. I am able to set the environment variables and make the API calls after saving blank values within the config node.
When I hit this breakpoint, I doesn't appear I'm able to discern if the credentials have been set and the input's are blank. Is there a way to tell or signal the UI that these were set already, so the UX isn't clunky?
