Array and table Ui problem
I restarted node red node again and I'm lost after so long, Im trying to represent a machine state in a table, i have one array:
msg.payload : array[3]
array[3]
0: "2023-10-31T14:17:02.515Z"
1: "Start"
2: "4"
How can i represent this array in ui table? The problem is that i dont have only one object in the array?
Thanks in advance.
Regards
Maybe this example will help
[{"id":"566c17275d3f7d3e","type":"inject","z":"b779de97.b1b46","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[\"2023-10-31T14:17:02.515Z\",\"Start\",\"4\"]","payloadType":"json","x":110,"y":4820,"wires":[["c51368d20c9a4fc9"]]},{"id":"c51368d20c9a4fc9","type":"template","z":"b779de97.b1b46","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"[\n    {\n    \"date\": \"{{{payload.0}}}\",\n    \"state\": \"{{{payload.1}}}\",\n    \"value\": {{{payload.2}}}\n    }\n]","output":"json","x":280,"y":4820,"wires":[["468f19b92a6fe741","24c6aa245669f02a"]]},{"id":"468f19b92a6fe741","type":"ui_table","z":"b779de97.b1b46","group":"4f791fdc1745d3d9","name":"","order":8,"width":0,"height":0,"columns":[{"field":"date","title":"Date","width":"","align":"left","formatter":"plaintext","formatterParams":{"target":"_blank"}},{"field":"state","title":"State","width":"","align":"left","formatter":"plaintext","formatterParams":{"target":"_blank"}},{"field":"value","title":"Value","width":"","align":"left","formatter":"plaintext","formatterParams":{"target":"_blank"}}],"outputs":0,"cts":false,"x":430,"y":4820,"wires":[]},{"id":"24c6aa245669f02a","type":"debug","z":"b779de97.b1b46","name":"debug 347","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":430,"y":4760,"wires":[]},{"id":"4f791fdc1745d3d9","type":"ui_group","name":"micro","tab":"c954274bbed7292e","order":1,"disp":false,"width":"18","collapse":false,"className":""},{"id":"c954274bbed7292e","type":"ui_tab","name":"Solar","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
Thank you so much E1cid, its work so fine!
One question more, if i read a csv to represent in a dashboard table, how can i do to have the last csv row in first table position (reverse the order of the csv in the table, see first in table the last row saved in csv)?
Thank you in advance.
Reverse the array
In a change node
set msg. payload
to value of J: $reverse($$.payload)
Thank you E1cid, all working fine!
