I'm having an issue where I am piping 16 bits of an arrange into a change node to give them English names but for some reason the output is only keeping the first 8 bits, or 8 statements and abandoning everything else.
Here is the flow overview:
and here is a snippit from the change node config
ideally this should process all 16 bits
The problem is the order you are doing the moves.
When you move payload[0] you are removing the first item of the array - so the array now has 15 elements and what was at index 1 is now at index 0. So when the next rule moves payload[1] it's actually moving what was originally payload[2] and so on.
I'd suggest changing from 'move' to 'set' to preserve the original array and then do a delete at the end.
Just be aware the set operation expects the arguments to be the other way around.
Thanks,
Blockquote
Blockquote
Was what i was sticking on, cheers.
