Ask for help with debug in node red
hi evryone can anyone help me with this :
i wana simulate code can control a system {pump-low start and stop by switch after pump-low start the pump-décolorant and pump-scalaut starting after 2 sec also pump-high start after 6 sec when switch is false all pump stoped}
but i get northing in debug any advise
here is the code :
// Declare variables for the pumps
let pumpLow;
let pumpDecolorant;
let pumpScalaut;
let pumpHigh;
// Declare a variable to track the status of the pumps
let pumpStatus = "off";
// This function is called when the switch is flipped
function startPumps(msg) {
// Check the value of the switch
if (msg.payload === true) {
// If the switch is turned on, start the pump-low
pumpLow = setInterval(function () {
console.log("pump-low started");
}, 1000); // Run the function every second
    // Set a timeout to start the pump-decolorant and pump-scalaut after 2 seconds
    setTimeout(function () {
        pumpDecolorant = setInterval(function () {
            console.log("pump-decolorant started");
        pumpScalaut = setInterval(function () {
            console.log("pump-scalaut started");
    }, 2000);
    // Set a timeout to start the pump-high after 6 seconds
        pumpHigh = setInterval(function () {
            console.log("pump-high started");
    }, 6000);
    // Update the pump status
    pumpStatus = "on";
} else {
    // If the switch is turned off, stop all pumps
    stopPumps();
// This function stops all pumps
function stopPumps() {
clearInterval(pumpLow);
clearInterval(pumpDecolorant);
clearInterval(pumpScalaut);
clearInterval(pumpHigh);
console.log("all pumps stopped");
pumpStatus = "off";
// Send the pump status to the output
return {
payload: pumpStatus
setTimeout functions may eventually create all kinds of problems, can I suggest a more node-red "way" of implementing this ?
Try this flow:
[{"id":"1622bb3abca3940f","type":"inject","z":"31c1e2adb95d7cd8","name":"pump start","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"true","payloadType":"bool","x":160,"y":60,"wires":[["b779a5bda71c5c6b"]]},{"id":"b779a5bda71c5c6b","type":"function","z":"31c1e2adb95d7cd8","name":"function 1","func":"\nif(msg.payload){\n    node.status({ fill: \"green\", shape: \"dot\", text: \"Pumps started\" });\n}\nelse{\n    node.status({ fill: \"red\", shape: \"dot\", text: \"Pumps stopped\" });\n}\nreturn msg","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":275,"y":80,"wires":[["eb6dfcad89e271f5"]],"l":false},{"id":"ab2f978a43b0451d","type":"inject","z":"31c1e2adb95d7cd8","name":"pumps stop","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"false","payloadType":"bool","x":150,"y":100,"wires":[["b779a5bda71c5c6b"]]},{"id":"9be737534ef39b61","type":"function","z":"31c1e2adb95d7cd8","name":"function 2","func":"if (msg.payload) {\n    node.status({ fill: \"green\", shape: \"dot\", text: \"pump-decolorant started\" });\n    return msg;\n}\nelse {\n    node.status({ fill: \"red\", shape: \"dot\", text: \"pump-decolorant stopped\" });\n}\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":555,"y":160,"wires":[[]],"l":false},{"id":"558eb0a27b419ae5","type":"delay","z":"31c1e2adb95d7cd8","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":420,"y":160,"wires":[["979a5e0e162278dc","9be737534ef39b61"]]},{"id":"eb6dfcad89e271f5","type":"switch","z":"31c1e2adb95d7cd8","name":"","property":"payload","propertyType":"msg","rules":[{"t":"false"},{"t":"true"}],"checkall":"true","repair":false,"outputs":2,"x":345,"y":80,"wires":[["979a5e0e162278dc","9be737534ef39b61","eeb91795a917d96a"],["558eb0a27b419ae5"]],"l":false},{"id":"1c4161b1161d26e6","type":"delay","z":"31c1e2adb95d7cd8","name":"","pauseType":"delay","timeout":"6","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":680,"y":80,"wires":[["eeb91795a917d96a"]]},{"id":"eeb91795a917d96a","type":"function","z":"31c1e2adb95d7cd8","name":"function 3","func":"if (msg.payload) {\n    node.status({ fill: \"green\", shape: \"dot\", text: \"pump-high started\" });\n    msg.payload = {pumpstatus:\"On\"}\n    return msg;\n}\nelse {\n    msg.payload = { pumpstatus: \"Off\" }\n    node.status({ fill: \"red\", shape: \"dot\", text: \"pump-high stopped\" });\n    return msg;\n\n}\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":785,"y":40,"wires":[["76261901fede0e36"]],"l":false},{"id":"979a5e0e162278dc","type":"function","z":"31c1e2adb95d7cd8","name":"function 4","func":"if (msg.payload) {\n    node.status({ fill: \"green\", shape: \"dot\", text: \"pump-scalaut started\" });\n    return msg;\n}\nelse {\n    node.status({ fill: \"red\", shape: \"dot\", text: \"pump-scalaut stopped\" });\n}\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":555,"y":100,"wires":[["1c4161b1161d26e6"]],"l":false},{"id":"76261901fede0e36","type":"debug","z":"31c1e2adb95d7cd8","name":"debug 2","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":845,"y":40,"wires":[],"l":false}]
thanks
but do you know how to stop the delay in the same time
because it remember the last msg of start
