Ask : two node to one function?
Dear All :
  1. The switch has topic is no2_pn, but hv error...why?
  2. In the code Line 20 that is correct?
  3. Or in the code has another error?
Thank u.
The error is because no2_pn is a String value so it needs to have " around it. The same is true for "no2_cali_val" and "no2_array".
if (msg.topic == "no2_pn")
Dear Sir :
I hope the output is no2_array, not "no2_array".
So how to do?
Thank u.
I'm sorry - I did not spot that no2_array was a locally defined variable.
So "no2_pn" and "no2_cali_val" are String types and need quotes.
no2_array is a local variable so does not need quotes.
Dear Sir :
Thank u.
  1. But if no "no2_array" that it still has error...
  2. How can I output value that is no2_array's vaule.
  3. Cause the value is numberic.
Thanks again.
Please share your code (not a screenshot, paste it in and format it as a code block using by wrapping it with ```.
What error are you now getting?
Dear Sir :
  1. The code is below:
//var i;
//var j;
var no2_array=[];
if(msg.topic=="no2_pn")
    if(msg.payload==true)
        no2_array[0]=0;  //+
    else
        no2_array[0]=1;  //-
if(msg.topic=="no2_cali_val")
    //1j=msg.payload;
    no2_array[1]=(msg.payload<<8);
    no2_array[2]=msg.payload&0xFF;
msg.payload="no2_array";
  1. So msg.payload's value is always string?
Thank u.
I have edited your last post, but next time that you post any code, please use three back ticks and not quotations.
Like this ```
and not """
No, no2_array is a variable and not a string, so you don't need string quotes around it.
So instead of msg.payload="no2_array"; you need msg.payload=no2_array;
Dear Sir :
  1. I will use ''' next time.
  2. its right : msg.payload=no2_array;
Thank u.
