Dear All :
Look at pic red circle, I want output no2_array[0~3] but only output no2_array[0]! Where im wrong?
Thank u.
your screenshot does not show us all of your function code so we cannot answer your question.
Please share the code, not a screenshot, and make sure you format it properly using the </> button.
Dear knolleary :
The function code is at below :
let no2_array=[0];
if(msg.topic=="no2_out")
if(msg.payload==true)
msg.payload=no2_array;
if(msg.topic=="no2_pn")
if(msg.payload=='+')
no2_array[0]=0;
else if(msg.payload=='-')
no2_array[0]=1;
if(msg.topic=="no2_cali_val")
if(msg.payload<=5000)
//1.Good,Show is Sring : ["1388", "13", "88"].
no2_array[1]=Number(msg.payload).toString(16);
no2_array[2]=msg.payload>>8;
no2_array[2]=Number(no2_array[2]).toString(16);
no2_array[3]=msg.payload&0xFF;
no2_array[3]=Number(no2_array[3]
Thank u.
The line
is missing )
The only return statement in your function is in the
if(msg.topic=="no2_out") { } block.
Dear jbudd :
Thank u.
Hi @jlian168
I think I understand what you are trying to do. You are trying to create no2_array using three different messages, before you send the full value.
The problem is the no2_array variable is reset every time the Function node receives a message.
To fix this, you need to use Context - Writing Functions : Node-RED. This lets you store values between different calls to the Function node.
You can use context.get to get a value from context, and context.set to set the value.
// Get the current value from context, or default to `[0]`
let no2_array=context.get("no2_array") || [0];
no2_array[0]=0;
no2_array[0]=1;
// Save it back to context
context.set("no2_array", no2_array)
@jlian168 please don't use this thread to direct all your questions at me. You have another thread for the flag question.
(But, I will tell you - change the ||[0] to ||0 because you want flag to default to the number 0 not an array as you have for no2_array.
What problem? I do not know what you want the flow to do, so I do not know what behaviour you want.
My guess is you want to reset no2_array after sending it. So where you have:
You could add a line to reset no2_array ready for the next user:
context.set("no2_array",[0]);
