Hi all, I'm programming a node-red code with digital input and output of mraa-gpio library. Periodically I obtain the following error:
Assertion `uv__has_active_reqs(req->loop)' failed.
can some one help me?
many thanks
many thanks
Hi @denissanga
without more context about the error (there must be more than just that in the error message?) then it is hard to be specific.
But a uv__... type error is coming from native code - so most likely a bug or issue with the mraa-gpio library. We aren't going to be able to help with an issue in a low-level library like that - you'd have to report it back to the maintainers of whichever mraa-gpio library you are using.
thank you very much for your answer.
I'm using a simple branch which read an digital input in iot2050 siemens and
digital input ON -> digital output OFF
digital input OFF -> digital output OFF
Always I can turn on the output but when I try turn off the external input the application crashes without other details if not the following line:
./src/threadpool.c:329: uv__queue_done: Assertion `uv__has_active_reqs(req->loop)' failed.
I'm using mraa-gpio library version 2.2.0 on iot2050siemens
many thanks
