Welcome to Node-RED
14 Dec 10:12:43 - [info] Node-RED version: v2.1.4
14 Dec 10:12:43 - [info] Node.js version: v14.17.3
14 Dec 10:12:43 - [info] Windows_NT 10.0.19042 x64 LE
14 Dec 10:15:53 - [info] Loading palette nodes
14 Dec 10:16:00 - [info] Dashboard version 3.1.2 started at /ui
14 Dec 10:16:01 - [info] Settings file : C:\Users\OEE.Hosur\.node-red\settings.js
14 Dec 10:16:01 - [info] Context store : 'default' [module=localfilesystem]
14 Dec 10:16:01 - [info] User directory : \Users\OEE.Hosur\.node-red
14 Dec 10:16:01 - [warn] Projects disabled : editorTheme.projects.enabled=false
14 Dec 10:16:01 - [info] Flows file : \Users\OEE.Hosur\.node-red\flows.json
14 Dec 10:16:01 - [info] +-----------------------------------------------------
14 Dec 10:16:01 - [info] | uibuilder v4.1.4 initialised
14 Dec 10:16:01 - [info] | root folder: \Users\OEE.Hosur\.node-red\uibuilder
14 Dec 10:16:01 - [info] | Using Node-RED's webserver at:
14 Dec 10:16:01 - [info] | http://10.180.18.18:1880/ or http://localhost:1880/
14 Dec 10:16:01 - [info] | Installed packages:
14 Dec 10:16:01 - [info] | jquery, socket.io
14 Dec 10:16:02 - [info] Server now running at http://127.0.0.1:1880/
14 Dec 10:16:02 - [info] Starting flows
14 Dec 10:16:02 - [info] [cronplus:48379b45fb9be286] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"schedule1","payloadType":"default","payload":"","expressionType":"cron","expression":"0 0 10 * * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
2021-12-14 04:46:02: Connecting to modbustcp slave at 10.180.18.50:502 unit_id: 0
CTOR: MessageCounterNode
INFO! 1 | minutes | true
timeToNextTick: 56942
timeToNextTick: 56939
timeToNextTick: 56936
timeToNextTick: 56934
timeToNextTick: 56932
timeToNextTick: 56930
timeToNextTick: 56928
timeToNextTick: 56926
timeToNextTick: 56924
timeToNextTick: 56920
timeToNextTick: 56917
timeToNextTick: 56914
timeToNextTick: 56912
timeToNextTick: 56909
timeToNextTick: 56906
timeToNextTick: 56904
timeToNextTick: 56903
timeToNextTick: 56901
timeToNextTick: 56899
timeToNextTick: 56897
timeToNextTick: 56828
14 Dec 10:16:03 - [info] [cronplus:6ae0de83c65eae55] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"schedule1","payloadType":"num","payload":"0","expressionType":"cron","expression":"0/2 * * * * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
14 Dec 10:16:03 - [info] [cronplus:25ebd2f2c9249a1a] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"schedule1","payloadType":"num","payload":"1","expressionType":"cron","expression":"0/2 * * * * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
14 Dec 10:16:03 - [info] [cronplus:Cron-8 Hour] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"schedule1","payloadType":"str","payload":"A","expressionType":"cron","expression":"0 1 14 * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
14 Dec 10:16:03 - [info] [cronplus:Cron-8 Hour] createTask - index: 1, static: true, opt: {"name":"schedule2","topic":"schedule2","payloadType":"str","payload":"B","expressionType":"cron","expression":"0 1 22 * * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
14 Dec 10:16:03 - [info] [cronplus:Cron-8 Hour] createTask - index: 2, static: true, opt: {"name":"schedule3","topic":"schedule3","payloadType":"str","payload":"C","expressionType":"cron","expression":"0 1 6 * * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
14 Dec 10:16:03 - [warn] Unknown context store 'memory' specified. Using default store.
14 Dec 10:16:03 - [info] [cronplus:Cron- Every Hour - A Shift] createTask - index: 0, static: true, opt: {"name":"s1","topic":"s1","payloadType":"num","payload":"1","expressionType":"cron","expression":"0 1 7 * * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
14 Dec 10:16:03 - [info] [cronplus:Cron- Every Hour - A Shift] createTask - index: 1, static: true, opt: {"name":"s2","topic":"s2","payloadType":"num","payload":"2","expressionType":"cron","expression":"0 1 8 * * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
14 Dec 10:16:03 - [info] [cronplus:Cron- Every Hour - A Shift] createTask - index: 2, static: true, opt: {"name":"s3","topic":"s3","payloadType":"num","payload":"3","expressionType":"cron","expression":"0 1 9 * * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
14 Dec 10:16:03 - [info] [cronplus:Cron- Every Hour - A Shift] createTask - index: 3, static: true, opt: {"name":"s4","topic":"s4","payloadType":"num","payload":"4","expressionType":"cron","expression":"0 1 10 * * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
14 Dec 10:16:03 - [info] [cronplus:Cron- Every Hour - A Shift] createTask - index: 4, static: true, opt: {"name":"s5","topic":"s5","payloadType":"num","payload":"5","expressionType":"cron","expression":"0 1 11 * * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
14 Dec 10:16:03 - [info] [cronplus:Cron- Every Hour - A Shift] createTask - index: 5, static: true, opt: {"name":"s6","topic":"s6","payloadType":"num","payload":"6","expressionType":"cron","expression":"0 1 12 * * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
14 Dec 10:16:03 - [info] [cronplus:Cron- Every Hour - A Shift] createTask - index: 6, static: true, opt: {"name":"s7","topic":"s7","payloadType":"num","payload":"7","expressionType":"cron","expression":"0 1 13 * * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
14 Dec 10:16:03 - [info] [cronplus:Cron- Every Hour - A Shift] createTask - index: 7, static: true, opt: {"name":"s8","topic":"s8","payloadType":"num","payload":"8","expressionType":"cron","expression":"0 1 14 * * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
14 Dec 10:16:03 - [info] [cronplus:Cron-Every Hour - B Shift] createTask - index: 0, static: true, opt: {"name":"s1","topic":"s1","payloadType":"num","payload":"1","expressionType":"cron","expression":"0 1 15 * * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
14 Dec 10:16:03 - [info] [cronplus:Cron-Every Hour - B Shift] createTask - index: 1, static: true, opt: {"name":"s2","topic":"s2","payloadType":"num","payload":"2","expressionType":"cron","expression":"0 1 16 * * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
14 Dec 10:16:03 - [info] [cronplus:Cron-Every Hour - B Shift] createTask - index: 2, static: true, opt: {"name":"s3","topic":"s3","payloadType":"num","payload":"3","expressionType":"cron","expression":"0 1 17 * * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
14 Dec 10:16:03 - [info] [cronplus:Cron-Every Hour - B Shift] createTask - index: 3, static: true, opt: {"name":"s4","topic":"s4","payloadType":"num","payload":"4","expressionType":"cron","expression":"0 1 18 * * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
14 Dec 10:16:03 - [info] [cronplus:Cron-Every Hour - B Shift] createTask - index: 4, static: true, opt: {"name":"s5","topic":"s5","payloadType":"num","payload":"5","expressionType":"cron","expression":"0 1 19 * * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
14 Dec 10:16:03 - [info] [cronplus:Cron-Every Hour - B Shift] createTask - index: 5, static: true, opt: {"name":"s6","topic":"s6","payloadType":"num","payload":"6","expressionType":"cron","expression":"0 1 20 * * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
14 Dec 10:16:03 - [info] [cronplus:Cron-Every Hour - B Shift] createTask - index: 6, static: true, opt: {"name":"s7","topic":"s7","payloadType":"num","payload":"7","expressionType":"cron","expression":"0 1 21 * * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
14 Dec 10:16:03 - [info] [cronplus:Cron-Every Hour - B Shift] createTask - index: 7, static: true, opt: {"name":"s8","topic":"s8","payloadType":"num","payload":"8","expressionType":"cron","expression":"0 1 22 * * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
14 Dec 10:16:03 - [info] [cronplus:Cron-Every Hour - C Shift] createTask - index: 0, static: true, opt: {"name":"s1","topic":"s1","payloadType":"num","payload":"1","expressionType":"cron","expression":"0 1 23 * * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
14 Dec 10:16:03 - [info] [cronplus:Cron-Every Hour - C Shift] createTask - index: 1, static: true, opt: {"name":"s2","topic":"s2","payloadType":"num","payload":"2","expressionType":"cron","expression":"0 1 00 * * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
14 Dec 10:16:03 - [info] [cronplus:Cron-Every Hour - C Shift] createTask - index: 2, static: true, opt: {"name":"s3","topic":"s3","payloadType":"num","payload":"3","expressionType":"cron","expression":"0 1 01 * * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
14 Dec 10:16:03 - [info] [cronplus:Cron-Every Hour - C Shift] createTask - index: 3, static: true, opt: {"name":"s4","topic":"s4","payloadType":"num","payload":"4","expressionType":"cron","expression":"0 1 02 * * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
14 Dec 10:16:03 - [info] [cronplus:Cron-Every Hour - C Shift] createTask - index: 4, static: true, opt: {"name":"s5","topic":"s5","payloadType":"num","payload":"5","expressionType":"cron","expression":"0 1 03 * * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
14 Dec 10:16:03 - [info] [cronplus:Cron-Every Hour - C Shift] createTask - index: 5, static: true, opt: {"name":"s6","topic":"s6","payloadType":"num","payload":"6","expressionType":"cron","expression":"0 1 04 * * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
14 Dec 10:16:03 - [info] [cronplus:Cron-Every Hour - C Shift] createTask - index: 6, static: true, opt: {"name":"s7","topic":"s7","payloadType":"num","payload":"7","expressionType":"cron","expression":"0 1 05 * * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
14 Dec 10:16:03 - [info] [cronplus:Cron-Every Hour - C Shift] createTask - index: 7, static: true, opt: {"name":"s8","topic":"s8","payloadType":"num","payload":"8","expressionType":"cron","expression":"0 1 06 * * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
14 Dec 10:16:03 - [info] [cronplus:Cron-8 Hour] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"schedule1","payloadType":"str","payload":"A","expressionType":"cron","expression":"0 1 7,8,9,10,11,12,13,14 * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
14 Dec 10:16:03 - [info] [cronplus:Cron-8 Hour] createTask - index: 1, static: true, opt: {"name":"schedule2","topic":"schedule2","payloadType":"str","payload":"B","expressionType":"cron","expression":"0 1 15,16,17,18,19,20,21,22 * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
14 Dec 10:16:03 - [info] [cronplus:Cron-8 Hour] createTask - index: 2, static: true, opt: {"name":"schedule3","topic":"schedule3","payloadType":"str","payload":"C1","expressionType":"cron","expression":"0 1 23 * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
14 Dec 10:16:03 - [info] [cronplus:Cron-8 Hour] createTask - index: 3, static: true, opt: {"name":"schedule4","topic":"schedule4","payloadType":"str","payload":"C2","expressionType":"cron","expression":"0 1 00,1,2,3,4,5,6 * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
14 Dec 10:16:03 - [info] [cronplus:Cron- Every 15 Minutes] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"schedule1","payloadType":"default","payload":"","expressionType":"cron","expression":"0 0/15 * * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
14 Dec 10:16:03 - [info] [cronplus:Cron- Every 5 Minutes] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"schedule1","payloadType":"default","payload":"","expressionType":"cron","expression":"0 * * * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
14 Dec 10:16:03 - [info] [cronplus:Cron- Every Minute] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"schedule1","payloadType":"global","payload":"time","expressionType":"cron","expression":"0 * * * * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
14 Dec 10:16:03 - [info] [cronplus:Cron- Every Minute] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"schedule1","payloadType":"default","payload":"","expressionType":"cron","expression":"0 * * * * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
timeToNextTick: 56658
timeToNextTick: 56657
timeToNextTick: 56655
timeToNextTick: 56654
timeToNextTick: 56653
timeToNextTick: 56652
timeToNextTick: 56650
timeToNextTick: 56649
timeToNextTick: 56648
timeToNextTick: 56646
timeToNextTick: 56645
timeToNextTick: 56644
timeToNextTick: 56640
timeToNextTick: 56638
timeToNextTick: 56637
timeToNextTick: 56635
timeToNextTick: 56634
timeToNextTick: 56633
timeToNextTick: 56606
14 Dec 10:16:03 - [info] [cronplus:Cron-Every Minute] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"schedule1","payloadType":"str","payload":"A","expressionType":"cron","expression":"0 * 6-13 * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
14 Dec 10:16:03 - [info] [cronplus:Cron-Every Minute] createTask - index: 1, static: true, opt: {"name":"schedule2","topic":"schedule2","payloadType":"str","payload":"B","expressionType":"cron","expression":"0 * 14-21 * * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
14 Dec 10:16:03 - [info] [cronplus:Cron-Every Minute] createTask - index: 2, static: true, opt: {"name":"schedule3","topic":"schedule3","payloadType":"str","payload":"C","expressionType":"cron","expression":"0 * 22-5 * * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
14 Dec 10:16:03 - [info] [cronplus:Cron-Every Minute] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"schedule1","payloadType":"num","payload":"1","expressionType":"cron","expression":"0 0/1 * * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
14 Dec 10:16:03 - [info] [cronplus:Cron-Every 8 Hours] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"schedule1","payloadType":"bool","payload":"true","expressionType":"cron","expression":"0 1 6/8 * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
14 Dec 10:16:03 - [info] [cronplus:Cron-Every Second] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"schedule1","payloadType":"bool","payload":"true","expressionType":"cron","expression":"* * * * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
14 Dec 10:16:03 - [info] [cronplus:95965f6ce97b9954] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"schedule1","payloadType":"date","payload":"","expressionType":"cron","expression":"* * * * * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
14 Dec 10:16:03 - [info] [cronplus:Cron-Every Minute] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"schedule1","payloadType":"date","payload":"","expressionType":"cron","expression":"0 * * * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
14 Dec 10:16:03 - [info] Started flows
14 Dec 10:16:04 - [error] [ui_led:7cd24a796c46e915] RangeError: Maximum call stack size exceeded
14 Dec 10:16:05 - [error] [ui_led:7cd24a796c46e915] RangeError: Maximum call stack size exceeded
14 Dec 10:16:06 - [error] [ui_led:7cd24a796c46e915] RangeError: Maximum call stack size exceeded
14 Dec 10:16:07 - [error] [ui_led:7cd24a796c46e915] RangeError: Maximum call stack size exceeded
14 Dec 10:16:08 - [error] [ui_led:7cd24a796c46e915] RangeError: Maximum call stack size exceeded
14 Dec 10:16:09 - [error] [ui_led:7cd24a796c46e915] RangeError: Maximum call stack size exceeded
14 Dec 10:16:10 - [error] [ui_led:7cd24a796c46e915] RangeError: Maximum call stack size exceeded
14 Dec 10:16:12 - [error] [ui_led:7cd24a796c46e915] RangeError: Maximum call stack size exceeded
14 Dec 10:16:13 - [error] [ui_led:7cd24a796c46e915] RangeError: Maximum call stack size exceeded
14 Dec 10:16:14 - [error] [ui_led:7cd24a796c46e915] RangeError: Maximum call stack size exceeded
14 Dec 10:16:15 - [error] [ui_led:7cd24a796c46e915] RangeError: Maximum call stack size exceeded
14 Dec 10:16:16 - [error] [ui_led:7cd24a796c46e915] RangeError: Maximum call stack size exceeded
14 Dec 10:16:17 - [error] [ui_led:7cd24a796c46e915] RangeError: Maximum call stack size exceeded
14 Dec 10:16:18 - [error] [ui_led:7cd24a796c46e915] RangeError: Maximum call stack size exceeded
14 Dec 10:16:19 - [error] [ui_led:7cd24a796c46e915] RangeError: Maximum call stack size exceeded
14 Dec 10:16:20 - [error] [ui_led:7cd24a796c46e915] RangeError: Maximum call stack size exceeded
14 Dec 10:16:21 - [error] [ui_led:7cd24a796c46e915] RangeError: Maximum call stack size exceeded
14 Dec 10:16:22 - [error] [ui_led:7cd24a796c46e915] RangeError: Maximum call stack size exceeded
14 Dec 10:16:23 - [error] [ui_led:7cd24a796c46e915] RangeError: Maximum call stack size exceeded
14 Dec 10:16:24 - [error] [ui_led:7cd24a796c46e915] RangeError: Maximum call stack size exceeded
14 Dec 10:16:25 - [error] [ui_led:7cd24a796c46e915] RangeError: Maximum call stack size exceeded
14 Dec 10:16:26 - [error] [ui_led:7cd24a796c46e915] RangeError: Maximum call stack size exceeded
14 Dec 10:16:27 - [error] [ui_led:7cd24a796c46e915] RangeError: Maximum call stack size exceeded
14 Dec 10:16:28 - [error] [ui_led:7cd24a796c46e915] RangeError: Maximum call stack size exceeded
14 Dec 10:16:29 - [error] [ui_led:7cd24a796c46e915] RangeError: Maximum call stack size exceeded
14 Dec 10:16:30 - [error] [ui_led:7cd24a796c46e915] RangeError: Maximum call stack size exceeded
14 Dec 10:16:31 - [error] [ui_led:7cd24a796c46e915] RangeError: Maximum call stack size exceeded
14 Dec 10:16:32 - [error] [ui_led:7cd24a796c46e915] RangeError: Maximum call stack size exceeded
14 Dec 10:16:33 - [error] [ui_led:7cd24a796c46e915] RangeError: Maximum call stack size exceeded
14 Dec 10:16:34 - [error] [ui_led:7cd24a796c46e915] RangeError: Maximum call stack size exceeded
14 Dec 10:16:35 - [error] [ui_led:7cd24a796c46e915] RangeError: Maximum call stack size exceeded
14 Dec 10:16:36 - [error] [ui_led:7cd24a796c46e915] RangeError: Maximum call stack size exceeded
14 Dec 10:16:37 - [error] [ui_led:7cd24a796c46e915] RangeError: Maximum call stack size exceeded
14 Dec 10:16:38 - [error] [ui_led:7cd24a796c46e915] RangeError: Maximum call stack size exceeded
14 Dec 10:16:39 - [error] [ui_led:7cd24a796c46e915] RangeError: Maximum call stack size exceeded
14 Dec 10:16:40 - [error] [ui_led:7cd24a796c46e915] RangeError: Maximum call stack size exceeded
14 Dec 10:16:41 - [error] [ui_led:7cd24a796c46e915] RangeError: Maximum call stack size exceeded
14 Dec 10:16:42 - [error] [ui_led:7cd24a796c46e915] RangeError: Maximum call stack size exceeded
14 Dec 10:16:42 - [info] Stopping flows
2021-12-14 04:46:42: Modbus TCP:Closing
CLEANUP
CLEANUP
CLEANUP
CLEANUP
CLEANUP
CLEANUP
CLEANUP
CLEANUP
CLEANUP
CLEANUP
CLEANUP
CLEANUP
CLEANUP
CLEANUP
CLEANUP
CLEANUP
CLEANUP
CLEANUP
CLEANUP
CLEANUP
CLEANUP
CLEANUP
CLEANUP
CLEANUP
CLEANUP
CLEANUP
CLEANUP
CLEANUP
CLEANUP
CLEANUP
CLEANUP
CLEANUP
CLEANUP
CLEANUP
CLEANUP
CLEANUP
CLEANUP
CLEANUP
CLEANUP
CLEANUP
2021-12-14 04:46:43: Disconnecting from modbustcp slave at 10.180.18.50:502
14 Dec 10:16:43 - [info] Stopped flows
Terminate batch job (Y/N)?
