ui_LED problem not showing on dashboard
I have installed the ui_LED on one machine and it works. I send it either a true and the LED goes GREEN.
Sending a ~true and it turns RED.
This is on NR 0.19.4
I installed the node on another machine running NR 0.19.5.
I can't see the LED on the dashboard.
I'll try other things, but I'm stuck on what to do.
what is the version of the dashboard?
2.9.8
I've been trying for 20+ minutes to update it.
From the web page it just doesn't work.
Trying from the CLI. Same.
From the CLI in the .node-red directory:
npm install node-red-dashboard
NO LUCK! :frowning:
This is what I see:
pi@TimePi:~/.node-red $ npm install node-red-dashboard
npm WARN node-red-project@0.0.1 No repository field.
npm WARN node-red-project@0.0.1 No license field.
+ node-red-dashboard@2.9.8
added 1 package, removed 1 package, updated 8 packages and audited 874 packages in 848.829s
found 6 low severity vulnerabilities
  run `npm audit fix` to fix them, or `npm audit` for details
Back to "that old problem", I fear.
This is also a bit of other info which may be helpful.
pi@TimePi:~/.node-red $ tail /home/pi/.npm/_logs/2019-02-01T07_14_22_566Z-debug.log
5 verbose stack     at <anonymous>
6 verbose cwd /home/pi/.node-red
7 verbose Linux 4.14.79+
8 verbose argv "/usr/bin/node" "/usr/bin/npm" "audit" "fix"
9 verbose node v8.12.0
10 verbose npm  v6.4.1
11 error code ELOCKVERIFY
12 error Errors were found in your package-lock.json, run  npm install  to fix them.
12 error     Missing: node-red-contrib-queue-gate@^1.1.0
13 verbose exit [ 1, true ]
which bit of this suggests it failed to you?
Well, for the last hour I can not update the dashboard from 2.9.8 to the latest.
The other machines have 2.13.x
The gui doesn't appear on the dashboard.
So I am trying to update from the CLI.
Still not working.
It completes, gives the reply as shown.
I reboot (not really happy doing it, but....)
Same version of the dashboard. 2.9.8
So, what do I do now to get it updated?
I am trying, but it is just confusing me.
The program gives me messages saying things are not up to date.
I am told to not worry about them.
So.....
Stuck.
:confounded:
Some how it has now updated.
The dashboard is now up to date and the LED is now showing.
Spoke too soon.
The LED appears, but sending true or false the LED doesn't change colour.
Code:
[{"id":"f1ee051d.a087c8","type":"inject","z":"c636aa5a.cc34","name":"","topic":"","payload":"false","payloadType":"bool","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":3490,"y":1860,"wires":[["511451c8.b6077"]]},{"id":"6aa4b5df.f7408c","type":"inject","z":"c636aa5a.cc34","name":"","topic":"","payload":"true","payloadType":"bool","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":3490,"y":1900,"wires":[["511451c8.b6077"]]},{"id":"511451c8.b6077","type":"ui_led","z":"c636aa5a.cc34","group":"bb53947.22a3b68","order":1,"label":"Main","name":"Main","x":3630,"y":1940,"wires":[]},{"id":"bb53947.22a3b68","type":"ui_group","z":"","name":"Telemetry","tab":"e57b580a.89d2d8","order":3,"disp":true,"width":"6","collapse":false},{"id":"e57b580a.89d2d8","type":"ui_tab","z":"","name":"JUNK1","icon":"dashboard","order":26}]
Screen shots:
Any update regarding this? I do not have LED on my dashboard neither. What should I do?
Which version of the Node-RED dashboard have you installed, and do you see any errors in the console log of your browser (where the dashboard is running)?
The Node-RED is running on my computer. I installed it through CMD based on this link:
https://nodered.org/docs/getting-started/windows?fbclid=IwAR13v5z748blFi2tM4cJ7VxlG5ugjOcl4MDXY0tPBL7IuK3l2lj77eIxb0E
The dashboard is running on my web browser (google). Dashboard Version 2.22.1.
I see the error here:
I have 5 days (~10hours) of Node-RED experience, so perhaps I am missing some basic thing.
Hi Pesel,
could it be that you have mixed up two questions? Think your screenshot is about the mp3 discussion, not about ui_led? Or am I mistaken?
No. In the same project I have 2 issue (: I connected a Siemens 1200 PLC to the system and I connected a LED and a switch to that. I can see in the node-RED if I switch on the PLC and I can also switch the LED in the node-RED. But I have no visualization on the dashboard for the LED. I found this ui_LED node, which is exactly for this purpose, but it doesn't want to work. I can not see it on the dashboard.
![node-red_UIled|690x379]
Can you export the nodes you have shown grouped (assuming they are the ones that are not working for you) and paste them here. See this post for how to do that.
Also open the Developer Console in the browser (how to do that depends on the browser, probably in Tools > Developer or something similar), refresh the page and see if any errors are shown.
Hello Colin!
I started my Node-RED right now and suprisignly it is working now!
But how? I did not change anything.
Possibly a browser caching issue.
Hi All.
Sorry to revive this archived item. My UI-LED isn't working at all... not even showing up grey in the dash.
Here is a copy of the node-red-log after restart:
 at Object.requireModule [as require] (/usr/lib/node_modules/node-red/node_modules/@node-red/registry/lib/externalModules.js:103:19)
    at Object.requireModule [as require] (/usr/lib/node_modules/node-red/node_modules/@node-red/registry/lib/util.js:50:45)
    at new LEDNodeConstructor (/home/pi/.node-red/node_modules/node-red-contrib-ui-led/dist/nodes/ui_led/ui_led.js:9:42)
    at Object.createNode (/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/flows/util.js:87:27)
    at Flow.start (/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/flows/Flow.js:206:48)
    at start (/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/flows/index.js:371:33) {
  code: 'module_not_allowed'
TypeError: Cannot read property 'padEnd' of undefined
    at Flow.start (/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/flows/Flow.js:254:62)
Error: Module not allowed
9 Dec 10:03:42 - [info] Started flows
9 Dec 10:03:44 - [info] [mqtt-broker:Bins Broker] Connected to broker: mqtt://localhost:1883
I have done numerous things to try to resolve it; up to and including restarting with a fresh rpi install (changed order of palette module installs, rebooting between every additional palette module install.
Here is a copy of the log after trying to change properties and deploying them:
9 Dec 10:22:33 - [info] Started flows
9 Dec 10:22:33 - [info] [mqtt-broker:Bins Broker] Connected to broker: mqtt://localhost:1883
9 Dec 10:24:07 - [info] Stopping flows
9 Dec 10:24:07 - [warn] Error saving flows: Cannot read property 'log' of undefined
9 Dec 10:24:07 - [warn] TypeError: Cannot read property 'log' of undefined
    at log_helper (/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/nodes/Node.js:499:16)
    at LEDNodeConstructor.Node.error (/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/nodes/Node.js:527:9)
    at Flow.stop (/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/flows/Flow.js:335:26)
    at /usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/flows/index.js:446:43
    at Array.forEach (<anonymous>)
    at stop (/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/flows/index.js:442:19)
    at /usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/flows/index.js:217:20
9 Dec 10:24:07 - [error] TypeError: Cannot read property 'log' of undefined
I don't know what else to do!
Node-red installed from the script just today.
Note: I did update a different rpi4 last Friday due to a failed SSD; had no issues whatsoever bringing that system back online. I uploaded a .json file to my browser after burning new system onto new ssd. I try the same thing today to create a new system for a new customer and the LEDs for the dash aren't working.
Any help will be appreciated.
Marshall
Show us the log from the node-red start.
Hi Colin.
Thanks for the reply.
Here is the log directly after booting up:
9 Dec 10:35:25 - [info] Started flows
9 Dec 10:35:26 - [info] [mqtt-broker:Bins Broker] Connected to broker: mqtt://localhost:1883
It's basically the same as after a restart, I hope it can help diagnose the issue.
Stop node red and start it again in a terminal
node-red-stop
node-red-start
And post the full output.
Here it is... it's long. It looks like an error or set of errors for every instance of the UI-LED I have.
Start Node-RED
Once Node-RED has started, point a browser at http://192.168.0.37:1880
On Pi Node-RED works better with the Firefox or Chrome browser
Use   node-red-stop                          to stop Node-RED
Use   node-red-start                         to start Node-RED again
Use   node-red-log                           to view the recent log output
Use   sudo systemctl enable nodered.service  to autostart Node-RED at every boot
Use   sudo systemctl disable nodered.service to disable autostart on boot
To find more nodes and example flows - go to http://flows.nodered.org
Starting as a systemd service.
9 Dec 12:55:18 - [info]
Welcome to Node-RED
9 Dec 12:55:18 - [info] Node-RED version: v2.1.4
9 Dec 12:55:18 - [info] Node.js  version: v14.18.2
9 Dec 12:55:18 - [info] Linux 5.10.63-v7l+ arm LE
9 Dec 12:55:18 - [info] Loading palette nodes
9 Dec 12:55:20 - [info] Dashboard version 1.0.2 started at /ui
9 Dec 12:55:20 - [info] Settings file  : /home/pi/.node-red/settings.js
9 Dec 12:55:20 - [info] Context store  : 'file' [module=localfilesystem]
9 Dec 12:55:20 - [info] Context store  : 'mem' [module=memory]
9 Dec 12:55:20 - [info] User directory : /home/pi/.node-red
9 Dec 12:55:20 - [info] Projects directory: /home/pi/.node-red/projects
9 Dec 12:55:20 - [info] Server now running at http://127.0.0.1:1880/
9 Dec 12:55:20 - [info] Active project : BinsLevel101
9 Dec 12:55:20 - [info] Flows file     : /home/pi/.node-red/projects/BinsLevel101/flow.json
9 Dec 12:55:20 - [info] Starting flows
9 Dec 12:55:21 - [info] Started flows
9 Dec 12:55:21 - [info] [mqtt-broker:Bins Broker] Connected to broker: mqtt://localhost:1883
