Hi!
Sorry my bad, this is the updated flow.
"id": "5c42798006c66cf9",
"type": "tab",
"label": "docs",
"disabled": false,
"info": "",
"env": []
"id": "af895c52e12cee21",
"type": "group",
"z": "5c42798006c66cf9",
"name": "client 2",
"style": {
"label": true,
"color": "#000000"
"nodes": [
"52b79c05fc2d13b9",
"edd35247be478004",
"33da1404a4f86a06",
"f14340a37e866581",
"b59c2d5703d7af40"
"x": 374,
"y": 79,
"w": 272,
"h": 242
"id": "27a29473dcb0799c",
"type": "group",
"name": "client 1",
"style": {
"label": true,
"color": "#000000"
"nodes": [
"f8e6f4e03ec6f437",
"df3b09823a0be235",
"dac69f93724f9be2",
"8e6687ef2a55ccf0"
"x": 74,
"y": 79,
"w": 272,
"h": 202
"id": "f8e6f4e03ec6f437",
"type": "ui_text",
"g": "27a29473dcb0799c",
"group": "5f373ce19a1aa290",
"order": 1,
"width": 0,
"height": 0,
"name": "nombre bot",
"label": "bot name:",
"format": "lalala",
"layout": "row-left",
"className": "main-title-content no-gap",
"x": 170,
"y": 120,
"id": "df3b09823a0be235",
"type": "ui_text",
"order": 2,
"width": 0,
"height": 0,
"label": "Query sql",
"format": "example query",
"layout": "col-center",
"x": 160,
"y": 240,
"id": "dac69f93724f9be2",
"type": "ui_text",
"order": 5,
"width": 0,
"height": 0,
"name": "accion de la integracion",
"label": "Accion de la integracion: ",
"format": "some info",
"className": "main-title-content no-gap text-formatting accion",
"x": 210,
"y": 200,
"id": "8e6687ef2a55ccf0",
"type": "ui_text",
"order": 3,
"width": 0,
"height": 0,
"name": "service",
"label": "asadad",
"format": "Publico",
"x": 160,
"y": 160,
"id": "52b79c05fc2d13b9",
"type": "ui_text",
"g": "af895c52e12cee21",
"group": "25bfd2e62c3836cb",
"order": 3,
"width": 0,
"height": 0,
"name": "query mysql",
"label": "query mysql",
"format": "asd",
"x": 470,
"y": 280,
"id": "edd35247be478004",
"type": "ui_text",
"order": 1,
"width": 0,
"height": 0,
"name": "plataforma",
"label": "platform",
"format": "http://www.google.com",
"x": 470,
"y": 240,
"id": "33da1404a4f86a06",
"type": "ui_text",
"order": 5,
"width": 0,
"height": 0,
"format": "some information",
"x": 510,
"y": 200,
"id": "f14340a37e866581",
"type": "ui_text",
"order": 4,
"width": 0,
"height": 0,
"name": "salida ws",
"label": "Salida al servicio:",
"x": 460,
"y": 160,
"id": "b59c2d5703d7af40",
"type": "ui_text",
"order": 2,
"width": 0,
"height": 0,
"format": "lalalal2",
"x": 470,
"y": 120,
"id": "e8a24a141a3f5bf4",
"type": "ui_template",
"group": "",
"name": "button collapse_expand groups CSS",
"order": 1,
"width": 0,
"height": 0,
"format": "<style>\nbody {\n background: -webkit-linear-gradient(\n 55deg,\n #518b8a 50%,\n #245aa5 100%,\n #b800e9 0%\n );\n -webkit-touch-callout: none !important;\n}\n\nbody.nr-dashboard-theme {\n font-family: -apple-system, BlinkMacSystemFont, Segoe UI, Roboto, Oxygen-Sans, Ubuntu, Cantarell, Helvetica Neue, sans-serif;\n}\nbody.nr-dashboard-theme md-toolbar,\nbody.nr-dashboard-theme md-content md-card {\n background-color: transparent !important;\n color: #FFFFFF;\n}\n\nui-card-panel {\n background-color: rgba(255,255,255,0.1) !important;\n border-radius: 10px !important;\n}\n \n.md-card.md-default-theme, md-card {\n border-radius: 10px;\n}\n\n.nr-dashboard-switch.ng-scope {\n background-color: rgba(255,255,255,.2) !important;\n}\n\n.nr-dashboard-switch.ng-scope:hover {\n background-color: rgba(255,255,255,.5) !important;\n}\n\n.nr-dashboard-theme .nr-dashboard-button .md-button {\n background-color: rgba(255,255,255,.2);\n}\n\n.md-button {\n border-radius: 10px;\n}\n.collapse_groups_btn:hover {\n background: rgba(255,255,255,1);\n color: #64bb5d;\n}\n.collapse_groups_btn {\n transition: background 0.2s, color 0.2s;\n background-color: rgba(255,255,255,0.1);\n position: relative;\n color: whitesmoke;\n border: solid;\n border-radius: 10px;\n right: 5px;\n font-family: -apple-system, BlinkMacSystemFont, Segoe UI, Roboto, Oxygen-Sans, Ubuntu, Cantarell, Helvetica Neue, sans-serif;\n}\n.nr-dashboard-cardpanel layout-column {\n background-color: rgba(255,255,255,0.2) !important;\n background-color: transparent !important;\n border-radius: 10px !important;\n}\n\n.nr-dashboard-theme ui-card-panel {\n border: solid;\n border-color: cadetblue;\n}\n\n.nr-dashboard-template {\n overflow-y: visible;\n}\n.nr-dashboard-theme md-content md-card {\n background-color: transparent !important;\n}\n\n.nr-dashboard-theme ui-card-panel p.nr-dashboard-cardtitle {\n color: #a1e7e3;\n font-weight: bold; \n}\n\n.no-gap{\n top: 0px !important;\n}\n.group-integracion{\n height: initial !important;\n}\n.main-title-content{\n align-items: flex-start !important;\n height: auto !important;\n position: relative !important;\n text-align: justify;\n}\n.nr-dashboard-cardcontainer {\n height: fit-content !important;\n width: auto !important;\n}\n.nr-dashboard-cardpanel p{\n min-height: 32px !important;\n position: relative;\n \n}\n.nr-dashboard-text .value{\n font-weight: normal !important;\n}\n.nr-dashboard-text p {\n margin-top: 0.5em;\n margin-right: 0.3em;\n}\n.group-integracion{\n font-weight: bold !important;\n}\n.ui-card-panel div div[style]{\n height: initial !important;\n}\n.body.nr-dashboard-theme md-sidenav{\n background-color: rgb(24 46 40 / 80%);\n}\n.md-sidenav-left.md-closed, md-sidenav.md-closed {\n transform: translate3d(-100%,0,0);\n}\n.md-toolbar-tools h1, .md-toolbar-tools h2, .md-toolbar-tools h3 {\n font-size: 22px;\n font-weight: bold;\n position: relative;\n left: 15px;\n}\n\n</style>\n\n<script>\ndocument.ontouchmove = function (e) {\n e.preventDefault();\n}\n</script>",
"storeOutMessages": true,
"fwdInMessages": true,
"resendOnRefresh": true,
"templateScope": "global",
"className": "",
"x": 830,
"y": 80,
"id": "3df796318f8bc20b",
"group": "",
"name": "btn agrupar todo",
"order": 0,
"width": 0,
"height": 0,
"format": "<script>\n let observer = new MutationObserver(function (mutations) {\n for (let mutation of mutations) {\n if (mutation.type === 'childList') {\n if (mutation.target.nodeName === 'MD-CONTENT') {\n if (mutation.addedNodes.length > 0) {\n for (let i = 0; i < mutation.addedNodes.length; i++) {\n if (mutation.addedNodes[i].nodeName === 'MD-TOOLBAR') {\n const toolbar = angular.element('#nr-dashboard-toolbar');\n let div = $('<div />');\n let button = $('<button type=\"button\" class= \"collapse_groups_btn\" id=\"toolbar-toggle-button\" onclick=\"toggleGroups()\">Agrupar Todo</button>');\n div.append(button);\n div[0].style.margin = '5px 5px 5px auto';\n toolbar.append(div);\n break;\n }\n }\n }\n }\n }\n }\n }),\n targetNode;\n\n function toggleGroups() {\n let toggleButtons = angular.element('.nr-dashboard-cardcarat');\n for (let i = 0; i < toggleButtons.length; i++) {\n if (toggleButtons[i].firstElementChild.className == 'fa fa-caret-up') {\n toggleButtons[i].click();\n };\n }\n }\n\n // Listen to all dashboard changes\n angular.element(async function () {\n try {\n targetNode = angular.element('#nr-dashboard')[0];\n let toolbar = angular.element('#nr-dashbard-toolbar');\n if (toolbar.length == 0) {\n observer.observe(targetNode, {\n attributes: false,\n childList: true,\n characterData: false,\n subtree: true\n });\n } else {\n let div = $('<div />');\n let button = $('<button type=\"button\" class= \"collapse_groups_btn\" id=\"toolbar-toggle-button\" onclick=\"toggleGroups()\">Agrupar Todo</button>');\n div.append(button);\n div[0].style.margin = '5px 5px 5px auto';\n toolbar.append(div);\n }\n } catch (err) {\n console.error(err);\n }\n });\n\n</script>",
"className": "",
"x": 760,
"y": 120,
"id": "5f373ce19a1aa290",
"type": "ui_group",
"name": "integration 1",
"tab": "4a9479ab3f4555f0",
"order": 1,
"disp": true,
"width": "6",
"collapse": true,
"className": "group-integracion"
"id": "25bfd2e62c3836cb",
"type": "ui_group",
"name": "Validacion",
"tab": "b70b0fa3501be886",
"order": 1,
"disp": true,
"width": "6",
"collapse": true,
"id": "4a9479ab3f4555f0",
"type": "ui_tab",
"name": "client 1",
"icon": "launch",
"order": 8,
"disabled": false,
"hidden": false
"id": "b70b0fa3501be886",
"type": "ui_tab",
"name": "client 2",
"icon": "launch",
"order": 10,
"disabled": false,
"hidden": false
