I am best to say a beginner compared to the knowledgeable people on this site.
Thankfully for this site i have read and fought through the beginning of the learning curve and found my self knowing enough about NR and its function to really want to know more .
I attempting to make a flow that will automatically reduce the input current limit of Battery chargers when AC loads external to the system go up. so that the generator is not over loaded.
I have made quite a bit of progress, but i am bit stuck trying to set up a divide function, to divide external loads ( Galley and 50hz ) it is watts by the system voltage, to then have Amps of the external loads, i would then like the result subtracted from the existing current limit. then written back to the system as you will see in the flow,
[{"id":"63aaa3e4.c45fec","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"5ecb14e4.29a8ec","type":"mqtt in","z":"63aaa3e4.c45fec","name":"Galley","topic":"shellies/shellyem-05EC0B/emeter/1/power","qos":"2","datatype":"auto","broker":"89c0f82.5aa2708","x":90,"y":20,"wires":[["aaf9f7d7.f96b18"]]},{"id":"aaf9f7d7.f96b18","type":"json","z":"63aaa3e4.c45fec","name":"","property":"payload","action":"","pretty":false,"x":210,"y":20,"wires":[["ae0a9070.6e2b7"]]},{"id":"74b9d194.34fe","type":"mqtt in","z":"63aaa3e4.c45fec","name":"50hz","topic":"shellies/shellyem-05EC0B/emeter/0/power","qos":"2","datatype":"auto","broker":"89c0f82.5aa2708","x":90,"y":100,"wires":[["a08aedcc.cb5b6"]]},{"id":"a08aedcc.cb5b6","type":"json","z":"63aaa3e4.c45fec","name":"","property":"payload","action":"","pretty":false,"x":210,"y":100,"wires":[["5e5bf59a.9bda2c"]]},{"id":"ae0a9070.6e2b7","type":"change","z":"63aaa3e4.c45fec","name":"","rules":[{"t":"set","p":"var1","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":370,"y":40,"wires":[["42508796.522828"]]},{"id":"42508796.522828","type":"change","z":"63aaa3e4.c45fec","name":"sum","rules":[{"t":"set","p":"payload","pt":"msg","to":"$flowContext('var1')+$flowContext('var2')","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":550,"y":80,"wires":[["d0f62079.878d2","974e82e0.ab801"]]},{"id":"d0f62079.878d2","type":"debug","z":"63aaa3e4.c45fec","name":"","active":false,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","x":770,"y":20,"wires":[]},{"id":"5e5bf59a.9bda2c","type":"change","z":"63aaa3e4.c45fec","name":"","rules":[{"t":"set","p":"var2","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":370,"y":100,"wires":[["42508796.522828"]]},{"id":"fc5c0b25.539d78","type":"mqtt in","z":"63aaa3e4.c45fec","name":"Voltage","topic":"shellies/shellyem-05EC0B/emeter/0/voltage","qos":"2","datatype":"auto","broker":"89c0f82.5aa2708","x":90,"y":220,"wires":[["1af4982c.0e8a58"]]},{"id":"c3ab30d9.c2fdc","type":"debug","z":"63aaa3e4.c45fec","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","x":470,"y":280,"wires":[]},{"id":"1af4982c.0e8a58","type":"json","z":"63aaa3e4.c45fec","name":"","property":"payload","action":"","pretty":false,"x":220,"y":220,"wires":[["4484e922.707898"]]},{"id":"974e82e0.ab801","type":"change","z":"63aaa3e4.c45fec","name":"","rules":[{"t":"set","p":"var3","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":730,"y":80,"wires":[["7f27a8ef.0d0008"]]},{"id":"4484e922.707898","type":"change","z":"63aaa3e4.c45fec","name":"","rules":[{"t":"set","p":"var4","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":370,"y":220,"wires":[["7f27a8ef.0d0008","fbe56ff2.7512c"]]},{"id":"7f27a8ef.0d0008","type":"change","z":"63aaa3e4.c45fec","name":"Divide ( =amps )","rules":[{"t":"set","p":"payload","pt":"msg","to":"$flowContext('var3')/$flowContext('var4')","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":720,"y":200,"wires":[["607f058f.80a91c","4b184003.9dcb9"]]},{"id":"607f058f.80a91c","type":"debug","z":"63aaa3e4.c45fec","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":900,"y":180,"wires":[]},{"id":"50b66d1e.8965b4","type":"mqtt in","z":"63aaa3e4.c45fec","name":"Current Limit","topic":"N/+/vebus/+/Ac/ActiveIn/CurrentLimit","qos":"0","datatype":"auto","broker":"fbe52f52.20bd7","x":110,"y":320,"wires":[["47f189e4.d7cf38"]]},{"id":"47f189e4.d7cf38","type":"json","z":"63aaa3e4.c45fec","name":"","property":"payload","action":"","pretty":false,"x":270,"y":320,"wires":[["6c7262f6.fea90c","c3ab30d9.c2fdc"]]},{"id":"6c7262f6.fea90c","type":"change","z":"63aaa3e4.c45fec","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.value","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":320,"y":420,"wires":[["cbab0ce2.4ea9"]]},{"id":"9c7f2d70.5d281","type":"mqtt out","z":"63aaa3e4.c45fec","name":"CCGX MQTT","topic":"W/506583dbfda4/vebus/257/Ac/ActiveIn/CurrentLimit","qos":"","retain":"","broker":"fbe52f52.20bd7","x":1120,"y":340,"wires":[]},{"id":"f549620a.9362","type":"change","z":"63aaa3e4.c45fec","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"value\": msg.payload}","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":900,"y":360,"wires":[["9c7f2d70.5d281","226f6e2d.107f82"]]},{"id":"226f6e2d.107f82","type":"debug","z":"63aaa3e4.c45fec","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","x":910,"y":460,"wires":[]},{"id":"2d09686e.ed3978","type":"change","z":"63aaa3e4.c45fec","name":"(CL) - (Galley / 50hz)","rules":[{"t":"set","p":"payload","pt":"msg","to":"$flowContext('var5')-$flowContext('var6')","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":680,"y":380,"wires":[["f549620a.9362"]]},{"id":"cbab0ce2.4ea9","type":"change","z":"63aaa3e4.c45fec","name":"","rules":[{"t":"set","p":"var5","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":450,"y":360,"wires":[["2d09686e.ed3978"]]},{"id":"4b184003.9dcb9","type":"change","z":"63aaa3e4.c45fec","name":"","rules":[{"t":"set","p":"var6","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":710,"y":280,"wires":[["2d09686e.ed3978"]]},{"id":"fbe56ff2.7512c","type":"debug","z":"63aaa3e4.c45fec","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","x":510,"y":140,"wires":[]},{"id":"89c0f82.5aa2708","type":"mqtt-broker","z":"","name":"RAS MQTT server","broker":"localhost","port":"1883","clientid":"","usetls":false,"compatmode":false,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"fbe52f52.20bd7","type":"mqtt-broker","z":"","name":"ccgx","broker":"192.168.150.71","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthRetain":"false","birthPayload":"","closeTopic":"","closeQos":"0","closeRetain":"false","closePayload":"","willTopic":"","willQos":"0","willRetain":"false","willPayload":""}]
here is the corresponding screen shot, i have removed the wire to the MQTT out put as something does not seam quite right. ( still leaning the disable tab feature )
