is it possible to autostart a function (function node) or when writing a new node sending automatically a message on deploy event ?
Is can be an invisible inject feature
the inject once feature implies a very visible and not to foget node, it what try to avoid...
Thx
You can make it smaller or even hide it underneath
Is there a specific reason why you want it to be invisible? With it invisible in the editor it might be harder to maintain on the longer term, but if it is inside a custom node you can document it easier. For maintenance that might be your best solution
visible is not the right word in fact. I want to spontaneously generate event at startup of a flow.
What exactly do you mean by "startup of a flow".
