Axis IP Cam Mjpeg Stream with multipart decoder
as rtsp streams dont work with multipart decoder without ffmpeg, i try to get the MJPEG Stream of an AXIS CAM.
I used the Dashboard before with an Foscam IP Cam and the URL =
http://IP:PORT/cgi-bin/CGIStream.cgi?cmd=GetMJStream&usr=USER&pwd=PASSWORD
but i cannot bring it to work with the AXIS IP CAM.
i tried these streams =
http://IP/mjpg/1/video.mjpg
http://IP/axis-cgi/mjpg/video.cgi
for the authentification i used the basic authentification on the multipart decoder.
That doesnt work. ("Unauthorized" below multipart decoder node)
next i tried these =
http://USER:PASSWORD@IP/axis-cgi/jpg/image.cgi
http://USER:PASSWORD@IP/axis-cgi/mjpg/video.cg
Doesnt work.("Unauthorized" below multipart decoder node)
So in my Browser i can use =
If i am logged into the Cam Webinterface
And i can use =
as well.
so how can i get the videostream from the AXIS IP CAM with working authentification ?
Dearly
Chorum
Yes indeed multipart streams having nothing to do with rtsp, so you cannot use my node for rtsp.
Could it be that your cam only supports digest authentication? Because the multipart-stream-decoder node only supports basic authentication...
Oh thanks for that Tip.
I changed the Auth on the Cam to Basic and it works :slight_smile:
Now i have to get the stream more fluid :slight_smile:
Thanks Again!
Chorum
