Backend and frontend communication
lower-case.js:
module.exports = function(RED) {
var myObject = {"x":1,"y":2};/myobject/
function LowerCaseNode(config) {
RED.nodes.createNode(this,config);
var node = this; t
his.on('input', function(msg) {
/??how to access "flow" object ?? flow.get("xxx")??/
msg.payload = msg.payload.toLowerCase();
node.send(msg); }); }
RED.nodes.registerType("lower-case",LowerCaseNode); }
lower-case.html:
</script type="text/javascript">
RED.nodes.registerType('lower-case',{ category: 'function', color: '#a6bbcf', defaults: { name: {value:""} },
inputs:1,
outputs:1,
icon: "file.png",
label: function() { return this.name||"lower-case"; },
oneditprepare: function () {
alert(myObject['x']);/?? how to get "js" object ??/
script>
thanks!
regard
Hi @cmdares
please try to format your code using the </> button in the formatting toolbar. That will make it much easier to read. It took me a while to spot your questions hidden in the code.
The documentation for using Context in your node is here: Node context : Node-RED
There is no built-in way for the editor side to directly access runtime variables. If you really need to do this, you would have to create a new admin HTTP endpoint in your .js file that you can call in your .html file to access the information.
There is a high-level description of how to do that here: javascript - Send data on configuration - Stack Overflow
thanks! I'll try the way.
