Hi, unfortunately i have no access to node red webinterface after installing the node: node red speaker pi
this is the error message:
is there also a possibilty to backup the flows, or where is the file location of the flows?
Many Thanks
Have you tried starting in safe mode node-red --safe?
You could also remove that node via the CLI - change to the .node-red directory (cd .node-red) and use npm remove node-red-contrib-speakerpi and then see if you can start up again.
after the remove, can you start node red?
no unfortunately not, the same error
Well you can remove the node in terminal by
cd .node-red' 'cd node_modules
then delete the folder for that node
rm -rf node-red-contrib-speakerpi
and then start node-red again.
Your flows are in the ~/.node-red directory.
where exactly?, this is the ls output
Why are you those folders. Start again with
cd $HOME
which should get you back to the Pi directory. Then
cd .node-red
then
You have shared the ls output of a completely different directory to the one I pointed you at.
it's not node red start it is node-red-start
yes also with node-red-start i got the error.
in the meantime i found the flows. I think I will start from scratch and flash a new raspbian.
Many Thanks for all your help.
