I am developing a ui for a bacnet network on a single subnet: 10.252.252.24/24 is the ip of the bacnet ip mstp router. I have 1 mstp device on mac address 1, mstp network number 3, mac address of router is 0, router device instance is 0.
I send a whois through node-red-contrib-bacnet, returns the objects and properties for the router, I can see its instance number etc. I can also view the roomsimulator running on my local machine 10.252.252.5:65322, with the client set at 10.252.252.24:47808 I can use node red to read and write properties when that address is set as my device in the bacnet read and write nodes, respectively.
I am trying to figure out what to put in the device section of the bacnet read or write nodes to reflect the mstp address of network 3, device 1.
I can view the connected sensor on yabe, connected to the router, I use yabe to see its device instance 1176856, and subscribe to the analog inputs/values. This tells me that the router is storing the mstp address somewhere.
I have probably read every bacnet publication on the internet, and before delving into bacpypes I thought it would be prudent to check here first. This is also my first post so forgive me if it is in the wrong section, I've searched every topic here under term "bacnet" and "mstp".
I've attached screenshots of the configurations used.
