I am using the BACnet integration. I have a virtual BACnet device setup, with a binary input as shown below hosted on 192.168.10.119.
And I have this code in Node-RED:
"id": "16d448de43b736aa",
"type": "BACnet-Read",
"z": "55b4538ddc27384f",
"objectType": "3",
"instance": "3a2c102cd631893f",
"propertyId": "85",
"device": "0b38fd2fc12a911a",
"server": "3effe912e7670a06",
"multipleRead": false,
"x": 300,
"y": 260,
"fefccd6a2db92a07"
"id": "3a2c102cd631893f",
"type": "BACnet-Instance",
"name": "Binary Input",
"instanceAddress": "0"
"id": "0b38fd2fc12a911a",
"type": "BACnet-Device",
"name": "PC",
"deviceAddress": "192.168.10.119:47808"
"id": "3effe912e7670a06",
"type": "BACnet-Client",
"name": "Node-RED",
"adpuTimeout": "6000",
"port": "47808",
"interface": "192.168.10.113",
"broadcastAddress": "192.168.10.255"
Whenever I try and read the device, I get the following responses:
To test my config, I switched the IP addresses as follows:
Node-RED server as "device" and the host running the BACnet simulator, as "client", After doing this, I receive this response:
I have Node-RED installed as a snap package on Ubuntu, running on Hyper-V, which works fine, and all firewalls have been disabled on the VM and also the machine hosting the BACnet device simulator.
Any ideas?
Thanks.
