Bacnet read problem
<Hello everyone,
in my project I am using the bacnet read node, I did some tests and it works perfectly, the problem is that to get the data I am forced to use an inject node with the "repeat" function,
considering that Node-Red is a drive event system, is it possible to use a node or a function that avoids me this constant polling which among other things also generates errors in the debug window? Thanks a lot Piero.
