Best way to parse Json object
Hi there,
i get a json object via MQTT from a CO2 sensor and need a tip how to extract the value of svalue 1129 and 23.0. the value 1129 is 5 or 4 digits.
Example:
{"idx":1,"RSSI":6,"nvalue":0,"svalue":"1129;23.0;33024.00“}
i am grateful for every tip.
Thanks Quito
A change node with a JSONata split expression might do the trick.
$split(payload.svalue, ';')
That should give you an array containing three values.
["1129", "23.0", "33024.00"]
If, in the MQTT node, you select the output as Parsed JSON then it will parse the JSON string for you and output a javascript object. Then you can reference the properties as, for example, msg.payload.svalue.
Then to parse svalue you can, in a function node, split it at the semi colons into an array using
const values = msg.payload.svalue.split(";")
Now values[0] will be the string "1129", values[1] will be "23.0" and so on.
Finally if you want the values as numbers rather than strings then you can use, for example
Number(values[0])
Hi kuema & colin,
Both examples work. Thank you very much :slight_smile:
