Thanks - edited and updated.
On the Node-RED Concepts page, the "Working with Wires" link in the Wire section is not relative and points to localhost.
Good spot - fixed. Thanks
https://nodered.org/docs/user-guide/runtime/configuration points to 'this guide':
https://nodered.org/docs/faq/settings-file which doesn't exist
Also missing the part about the flow credentials.
Thanks @bakman2 - fixes pushed
bottom of this page
https://nodered.org/docs/getting-started/raspberrypi
adding node to the palette 404s
Thanks - fix pushed. Also spotted the 'adding nodes to the palette' page wasn't on any of the index pages - also fixed.
There is some contradicting information in:
https://nodered.org/docs/creating-nodes/first-node#testing-your-node-in-node-red
vs
https://nodered.org/docs/creating-nodes/packaging#testing-a-node-module-locally
Go on. Give a clue
First link talks about:
npm install <location of node module>
Second link:
To test a node module locally, the
npm linkcommand can be used.
thanks - will fix. (Either will work - npm link was the "old way" - npm install now creates the links instead - so npm install cleaner and more consistent with installing all nodes.)
