BigTimer alternative for sunrise > sunset
I've used BigTimer for many years and it it very good, except I find that the sunrise / sunset times are a bit off (yes I have inputted location coordinates). I find I'm always having to adjust offsets.
Are there any other good alternatives anyone can recommend?
Thanks!
Here you go:
Thank you!
I should have said I am using BigTimer to control a gate node at sunset/sunrise. Would cron-plus be suitable do you think?
More than capable of doing what you want.
I have it installed on my test system, will read some more, thanks!
Don't be put off by the options it offers, it can also just be a simple timer.
And the best bit is that the author is a member of the node-red team, so you will always get support here. Have fun!
If you want something simpler than CRON+ but with good astro features, I also use node-red-contrib-sun-position
