Broken dependency after migration
Today I had to migrate my IOT VM from a AMD64 system to a ARMv7. I ran it on a photon+docker host and now is installed in a Raspbian+docker in a raspberry.
I simply moved the node-red docker volume with all it's contents to the new appliance so naively.
Now when I enter nodered, I face the "Flows stopped due to missing node types (mysensorsdb)" hint.
Inspecting the logs (in docker) I find the following messages:
> node-red-docker@1.0.4 start /usr/src/node-red,
> node $NODE_OPTIONS node_modules/node-red/red.js $FLOWS "--userDir" "/data",
7 Apr 21:46:57 - [info] ,
Welcome to Node-RED,
7 Apr 21:46:57 - [info] Node-RED version: v1.0.4,
7 Apr 21:46:57 - [info] Node.js  version: v12.16.1,
7 Apr 21:46:57 - [info] Linux 4.19.97-v7+ arm LE,
7 Apr 21:46:58 - [info] Loading palette nodes,
7 Apr 21:47:05 - [info] +-----------------------------------------------------,
7 Apr 21:47:05 - [info] | uibuilder initialised:,
7 Apr 21:47:05 - [info] |   root folder: /data/uibuilder,
7 Apr 21:47:05 - [info] |   version . .: 2.0.7,
7 Apr 21:47:05 - [info] |   packages . : vue,bootstrap,bootstrap-vue,socket.io,http-vue-loader,vue-moment,vue-router,axios,vue-axios,
7 Apr 21:47:06 - [warn] ------------------------------------------------------,
7 Apr 21:47:06 - [warn] [node-red-contrib-mysensors/mysdb] Error: Cannot find module '/data/node_modules/sqlite3/lib/binding/node-v72-linux-arm/node_sqlite3.node',
Require stack:,
- /data/node_modules/sqlite3/lib/sqlite3.js,
- /data/node_modules/sqlite/main.js,
- /data/node_modules/node-red-contrib-mysensors/dist/lib/database-sqlite.js,
- /data/node_modules/node-red-contrib-mysensors/dist/nodes/mysensors-db.js,
- /usr/src/node-red/node_modules/@node-red/registry/lib/loader.js,
- /usr/src/node-red/node_modules/@node-red/registry/lib/index.js,
- /usr/src/node-red/node_modules/@node-red/runtime/lib/nodes/index.js,
- /usr/src/node-red/node_modules/@node-red/runtime/lib/index.js,
- /usr/src/node-red/node_modules/node-red/lib/red.js,
- /usr/src/node-red/node_modules/node-red/red.js,
7 Apr 21:47:06 - [warn] [node-red-node-sqlite/sqlite] Error: Cannot find module '/data/node_modules/sqlite3/lib/binding/node-v72-linux-arm/node_sqlite3.node',
Require stack:,
- /data/node_modules/node-red-node-sqlite/sqlite.js,
7 Apr 21:47:06 - [info] Settings file  : /data/settings.js,
7 Apr 21:47:06 - [info] Context store  : 'default' [module=memory],
7 Apr 21:47:06 - [info] User directory : /data,
7 Apr 21:47:06 - [warn] Projects disabled : editorTheme.projects.enabled=false,
7 Apr 21:47:06 - [info] Flows file     : /data/flows.json,
7 Apr 21:47:06 - [info] Server now running at http://127.0.0.1:1880/,
7 Apr 21:47:06 - [warn] ,
7 Apr 21:47:06 - [info] Waiting for missing types to be registered:,
7 Apr 21:47:06 - [info]  - mysensorsdb,
So it's proven that my system is not platform agnostic.
Is there a way to make it download/repair the required dependencies without rolling it all and re-importing the flows? That shouldn't be easy...
Connect into your running container and run: npm rebuild in /data to rebuild the native modules for the new architecture.
You might need to run npm install sqlite3 as well.
Spectacular. Your indications fixed the installation and in record time.
Thank you very much.
