Show us the whole of the startup log please. You can copy out of the terminal using Ctrl-Shift-C then paste it here. Put a line containing three backtick characters before it and another such line after, that stops the forum 'helpfully' re-formatting it.
gb@HA-KINO-PC ~/Desktop $ node-red
26 Nov 16:20:41 - [info]
Welcome to Node-RED
26 Nov 16:20:41 - [info] Node-RED version: v0.19.5
26 Nov 16:20:41 - [info] Node.js version: v8.13.0
26 Nov 16:20:41 - [info] Linux 3.16.0-38-generic ia32 LE
26 Nov 16:20:42 - [info] Loading palette nodes
26 Nov 16:20:44 - [warn] rpi-gpio : Raspberry Pi specific node set inactive
26 Nov 16:20:44 - [warn] rpi-gpio : Cannot find Pi RPi.GPIO python library
26 Nov 16:20:47 - [warn] ------------------------------------------------------
26 Nov 16:20:47 - [warn] [node-red-node-sqlite/sqlite] Error: Cannot find module '/home/gb/.node-red/node_modules/sqlite3/lib/binding/node-v57-linux-ia32/node_sqlite3.node'
26 Nov 16:20:47 - [info] Settings file : /home/gb/.node-red/settings.js
26 Nov 16:20:47 - [info] Context store : 'default' [module=memory]
26 Nov 16:20:47 - [info] User directory : /home/gb/.node-red
26 Nov 16:20:47 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
26 Nov 16:20:47 - [info] Flows file : /home/gb/.node-red/flows_HA-KINO-PC.json
26 Nov 16:20:47 - [info] Server now running at http://127.0.0.1:1880/
your credentials.
26 Nov 16:20:48 - [info] Waiting for missing types to be registered:
26 Nov 16:20:48 - [info] - ui_base
26 Nov 16:20:48 - [info] - ui_tab
26 Nov 16:20:48 - [info] - ui_group
26 Nov 16:20:48 - [info] - profile
26 Nov 16:20:48 - [info] - sqlitedb
26 Nov 16:20:48 - [info] - ui_gauge
26 Nov 16:20:48 - [info] - ui_chart
26 Nov 16:20:48 - [info] - ui_dropdown
26 Nov 16:20:48 - [info] - ui_ui_control
26 Nov 16:20:48 - [info] - throttle
26 Nov 16:20:48 - [info] - thingspeak42
26 Nov 16:20:48 - [info] - ui_text
26 Nov 16:20:48 - [info] - gate
26 Nov 16:20:48 - [info] - moment
26 Nov 16:20:48 - [info] - ui_template
26 Nov 16:20:48 - [info] - ui_button
^C26 Nov 16:20:59 - [info] Stopping flows
26 Nov 16:20:59 - [info] Stopped flows
gb@HA-KINO-PC ~/Desktop $ ^C
Actually I suspect I know the problem. I suspect you had not been using --save when installing nodes, and later versions of npm uninstall any nodes that are not referenced in package.json. If you go to Manage Palette in node-red you can re-install the nodes and now they will automatically be added to package.json so you will not get the problem again. The ui_ nodes are from node-red-dashboard so re-installing that will sort them.
As I suspected, so npm has uninstalled all the other nodes. Not very user friendly of it to do that without warning, it caught me out a little while ago too. I am afraid you will just have to re-install the extra nodes you were using.
[Edit] Can you post the startup log too please, just to check there isn't anything else.
gb@HA-KINO-PC ~/.node-red $ npm install node-red-dashboard
npm notice created a lockfile as package-lock.json. You should commit this file.
+ node-red-dashboard@2.11.0
added 56 packages from 48 contributors, removed 108 packages and audited 106 packages in 24.315s
found 0 vulnerabilities
Getting better all thats missing is
26 Nov 16:49:33 - [info] Waiting for missing types to be registered:
26 Nov 16:49:33 - [info] - profile
26 Nov 16:49:33 - [info] - sqlitedb
26 Nov 16:49:33 - [info] - throttle
26 Nov 16:49:33 - [info] - thingspeak42
26 Nov 16:49:33 - [info] - gate
26 Nov 16:49:33 - [info] - moment
^C26 Nov 16:50:49 - [info] Stopping flows
By the way, if you are using a recent Debian based system such as Xubuntu then you can update to the latest version using the Pi install/upgrade script from https://nodered.org/docs/hardware/raspberrypi. That ensures that you get a consistent set of base nodes and tools. Also it will install a systemd startup script if you want it to run on boot.
Has this occured because you've updated npm, and the newer version has automatically removed those nodes that were originally installed via cmd and not included in the npm manifest.
