How to add a few buttons at the header so that they are visible/available in all the pages for action.
Unless I'm mistaken, each dashboard page is independent and has its own header. There is an option to define global (all-page) CSS classes, but as far as I know this is not possible for widgets, which need to be associated to a single selected page.
One way to bypass this could be using template nodes which import common shared elements.
This can be achieved within a UI Template node using Teleport: Template ui-template | Node-RED Dashboard 2.0
I'd like us to introduce the option for every widget to have a "location" field (or something similar) which can be group/slot, where the slot option allows you to place that widget in the header, sidebar or other useful locations
Thanks for the direction.
it is appearing on ALL pages as expected when i make ui-template (Widget UI Scoped).
But for some reason, clicking the button does not give any result in the attached debug node.
EDIT: this is in hte template node. (copied from dashboard.flowfuse)
<template>
<Teleport v-if="mounted" to="#app-bar-title">
<v-btn>Button 1</v-btn>
<v-btn>Button 2</v-btn>
</Teleport>
</template>
<script>
export default {
data() {
return {
mounted: false
mounted() {
this.mounted = true
</script>
The v-btns in your template have no click handlers. They are doing exactly what you have programmed them to do (nothing).
Here is an example of what you could do...
<v-btn @click="send({payload:'button 1'})">Button 1</v-btn>
<v-btn @click="send({payload:'button 2'})">Button 2</v-btn>
Thanks a lot.
With this 'button in headers', I can clear up so much real estate in my dashboard.
