Buttons size Dashboard
Hello, everyone,
a long search on the internet has led me to you.
I hope you can help me!
Node-Red runs from Ubuntu, I want to visualize my controller (Step7).
I use SVG images for this and it works the way I want it to. Resolution 1024x768, well now I have the problem that my buttons are huge and I can't find a way to make them small. (I couldn't find a solution!!)
Is there a way to integrate the buttons into SVG and to position and design them sensibly.
In addition to the pump, an ON/OFF button is the idea
thanks greetings
I have used the ui-led node to get the following display on my dashboard. Each led can be a square or a circle which can be any color you want it to be.
My led colors are based on the MQTT inputs they receive from my MQTT client.
