Calculate rain precipitation from URL with columns
Via the URL https://gpsgadget.buienradar.nl/data/raintext/?lat=52.37&lon=4.89 I can get the expected rainfall for the next two hours for a GPS location. This is shown in two columns, the amount of precipitation on the left and the time per 5 minutes on the right.
Although I get a JSON Parse Error I can request the two columns in NR with a http request (see attachment).
I would like to calculate the rainfall for the next hour so I have to add the first twelve values from the left column. Can someone explain to me how I can properly request the data and then calculate the rainfall for the next hour?
Its not JSON so switch that option off.
Next try feeding the payload to a split node.
Thanks Steve, the JSON error is not showing anymore. I've added the split node and now the rows are shown separately (see attachment).
I have too little experience with NR to work this out further, so I hope someone can explain to me exactly how to do this.
Could you export your flow and
paste it between backticks like this
Myself or another kind member will help you out
Thanks again! Would be great if someone can help me out :wink:
[{"id":"c0785c86.682e","type":"tab","label":"Flow 2","disabled":false,"info":""},{"id":"a322a220.a74e9","type":"http request","z":"c0785c86.682e","name":"GET Data","method":"GET","ret":"txt","paytoqs":false,"url":"https://gpsgadget.buienradar.nl/data/raintext/?lat=52.37&lon=4.89","tls":"","persist":false,"proxy":"","authType":"","x":400,"y":100,"wires":[["b7bc2e91.ccb9a"]]},{"id":"7d17f83d.1d5638","type":"inject","z":"c0785c86.682e","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":220,"y":100,"wires":[["a322a220.a74e9"]]},{"id":"6df9daa3.ba89a4","type":"debug","z":"c0785c86.682e","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":750,"y":100,"wires":[]},{"id":"b7bc2e91.ccb9a","type":"split","z":"c0785c86.682e","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":true,"addname":"topic","x":570,"y":100,"wires":[["6df9daa3.ba89a4"]]}]
To get you started...
[{"id":"c18a41c1.78301","type":"http request","z":"c90da02f.d57d2","name":"GET Data","method":"GET","ret":"txt","paytoqs":false,"url":"https://gpsgadget.buienradar.nl/data/raintext/?lat=52.37&lon=4.89","tls":"","persist":false,"proxy":"","authType":"","x":740,"y":100,"wires":[["745545df.f5010c"]]},{"id":"5bfe12a7.97f05c","type":"inject","z":"c90da02f.d57d2","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":580,"y":100,"wires":[["c18a41c1.78301"]]},{"id":"745545df.f5010c","type":"function","z":"c90da02f.d57d2","name":"split and map","func":"//first split each line into an array\nvar lines = msg.payload.trim().split(\"\\n\");\n\n//next map each element of the lines\n//array into an object with .time and .value\nvar errors = [];\nvar count = lines ? lines.length : 0;\nvar data = [];\nif(count){\n    data = lines.map((e) =>{\n        try{\n            let parts = e.split(\"|\");\n            return {\n                time: parts[1].trim(),\n                value: parseInt(parts[0])\n            }        \n        } catch(error) {\n            errors.push(\"Error splitting '\" + e + \"': \" + error)\n        }\n    })   \n}\n\n//return the data\nmsg.payload = {\n    count,\n    errors,\n    data\n}\n\nreturn msg;","outputs":1,"noerr":0,"x":570,"y":180,"wires":[["9b0d5e51.65864"]]},{"id":"9b0d5e51.65864","type":"debug","z":"c90da02f.d57d2","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":740,"y":180,"wires":[]}]
Hi Steve,
Very helpfull and appreciated, thanks!
Best regards, Hans.
