Usage of buienradar rain prediction
I would like to use the Home Assistant Buienradar intergration to calculate the rainfall for 5 days.
In HA there are rain 1d to rain 5d. if average is <10 I want my irrigation to run on some days.
And then I run into a problem, what shoud i use? and how to set calculator node
please some help
outputProperties array[3]
0: object
property: "payload"
propertyType: "msg"
value: ""
valueType: "entityState"
1: object
property: "data"
propertyType: "msg"
value: ""
valueType: "eventData"
2: object
property: "topic"
propertyType: "msg"
value: ""
valueType: "triggerId"
Hi. As I am sure you can see, that data you posted has nothing useful for us to try and help you.
Could you capture the output data once more but use the built in "Copy Value" button so that usable JSON is copied. You can find this "Copy Value" button by hovering your mouse over the payload.
PS, please always press the </> code button in the forum post toolbar BEFORE pasting code - to ensure the code is not corrupted/formatted by the forum.
I would install the buienradar node in node-red.
You can get the values, run it through a change node with jsonata to average the data
example flow (requires this node to be installed)
[{"id":"7cba216f9bea0f5d","type":"buienradar","z":"f8b839d1b6352dff","name":"","station":"6215","interval":"60000","forecast":true,"x":314,"y":96,"wires":[["3f42dc5d8b3da22e","daf8e598e8677e04"]]},{"id":"3f42dc5d8b3da22e","type":"change","z":"f8b839d1b6352dff","name":"get average","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.$average(**.kansregen)","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":502,"y":96,"wires":[["0873602b9d3d8a09"]]},{"id":"7a52cd85ee1cfb8e","type":"debug","z":"f8b839d1b6352dff","name":"yes","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":786,"y":72,"wires":[]},{"id":"0873602b9d3d8a09","type":"switch","z":"f8b839d1b6352dff","name":"<10 ?","property":"payload","propertyType":"msg","rules":[{"t":"lt","v":"10","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":642,"y":96,"wires":[["7a52cd85ee1cfb8e"],["a6cd85a8efca5712"]]},{"id":"a6cd85a8efca5712","type":"debug","z":"f8b839d1b6352dff","name":"no","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":786,"y":120,"wires":[]},{"id":"4398cdd8acb0f2ed","type":"inject","z":"f8b839d1b6352dff","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":156,"y":96,"wires":[["7cba216f9bea0f5d"]]},{"id":"daf8e598e8677e04","type":"debug","z":"f8b839d1b6352dff","name":"yes","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":478,"y":192,"wires":[]}]
for the buienradar rain 1d to 5d :[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}]
for the calculator these settings.
|Node|"c4a193f038f5a9ff"|
|Type|calculator|
|Module|node-red-contrib-calc|
|inputMsgField|"eventData"|
|outputMsgField|"payload"|
|operation|"avg"|
|constant|"5"|
|round|true|
|decimals|0|
I hope this is what you mean, i cannot find anything else as an output.
bakman 2
thank you for your help, I've got it working. I also want to use a switch with a if not rule.
Would you be able to help?
rule should be:
if not switched on by Pomp is ingeschakeld getriggerd door service switch.turn_on should have an yes and no output
