Calculations HTTP Request received data string
Because I have little experience with NodeRED, I run into a problem. With an HTTP Request I retrieve the data as in the graphic, a left column with 24 values and a right column with 24 times.
I want to add the first 3 values of the left column (green square) to be processed further. In the example, that value would be 154.
Can someone tell me how to do that?
[{"id":"a7ca5e83.ddd39","type":"tab","label":"Rain","disabled":false,"info":""},{"id":"566ef5f9.d235fc","type":"inject","z":"a7ca5e83.ddd39","name":"","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":180,"y":100,"wires":[["9fc6992c.30f8a8"]]},{"id":"9fc6992c.30f8a8","type":"http request","z":"a7ca5e83.ddd39","name":"","method":"GET","ret":"obj","paytoqs":"ignore","url":"https://gpsgadget.buienradar.nl/data/raintext?lat=51&lon=3","tls":"","persist":false,"proxy":"","authType":"basic","x":350,"y":100,"wires":[["85f8de99.1bb49"]]},{"id":"85f8de99.1bb49","type":"debug","z":"a7ca5e83.ddd39","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":530,"y":100,"wires":[]}]
There are multiple ways to do this, you could run the string throug a cvs node to convert to an array of objects then use Javascript or JSONata to sum the first 3 array values.
e.g.
[{"id":"566ef5f9.d235fc","type":"inject","z":"a7ca5e83.ddd39","name":"","props":[{"p":"payload","v":"","vt":"date"},{"p":"topic","v":"","vt":"string"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":90,"y":80,"wires":[["e9b1d32a.56ac38"]]},{"id":"e9b1d32a.56ac38","type":"template","z":"a7ca5e83.ddd39","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"000|14:05\n077|14:10\n077|14:15\n092|14:20\n092|14:25","output":"str","x":250,"y":80,"wires":[["776da0a1.f6fc"]]},{"id":"776da0a1.f6fc","type":"csv","z":"a7ca5e83.ddd39","name":"","sep":"|","hdrin":"","hdrout":"none","multi":"mult","ret":"\\n","temp":"value,time","skip":"0","strings":true,"include_empty_strings":"","include_null_values":"","x":390,"y":80,"wires":[["25f6f6be.47474a"]]},{"id":"25f6f6be.47474a","type":"change","z":"a7ca5e83.ddd39","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$sum(payload[[0..2]].[$number(value)].*)","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":490,"y":140,"wires":[["85f8de99.1bb49"]]},{"id":"85f8de99.1bb49","type":"debug","z":"a7ca5e83.ddd39","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":690,"y":140,"wires":[]}]
I could not have imagined that or it would have cost me a lot of time and frustration. That's why I'm very glad you helped me, thank you!
