Extract String from Text as result from http-request
I'm pretty new to node red and after accessing my hue devices I want to integrate a myStrom switch which delivers also a temperature value.
Instead of using some palett (node-red-contrib-mystrom
) I also could adress my the switch via http:///temp and therefore I use a http-request and a text output.
In the end it doesn't matter which way I go as the result is the same.
The result looks like this: {"measured":37.62,"compensation":19,"compensated":18.62,"offset":0}
As I want to display the result in a gauge im only interested in the value 19 - everything else needs to be deleted.
How can I achieve that ? Thanks for some hints
You don't need to delete anything. Just use the value of interest in the UI element (or move the property you need to payload using a change node)
If you don't know how to get the correct path to the value of interest - there’s a great page in the docs that will explain how to use the debug panel to find the right path to any data item.
https://nodered.org/docs/user-guide/messages
Is that coloured all red in the debug widow?
If so in the http request node at bottom, set it to return a json object, not a utf8 string. Then use msg.payload.compensation to access the value
though I suspect the actual temp is the compensated property
thanks a lot - that helped
also thanks to the others who replied
