Is it possible to call "link call" from a function and then work with what it returns?
Thank you and take care!
Hi @S0T0
No, it is not possible to do that.
Split the function in two and call the link in the middle.
If you really want everything in one function node (although not all in JavaScript), you could do this. Not seriously recommended.
[{"id":"58a0314dfaabdb02","type":"function","z":"e4d8efb5c97ba927","name":"function","func":"if (!msg._return) {\n// start function \n// optional, if link-call has dynamic target\n// msg.target = 'subroutine'\n msg._return = true\n return [null,msg]\n} else {\n// finish function\n delete msg._return\n return[msg,null]\n}\nreturn msg;","outputs":2,"noerr":0,"initialize":"","finalize":"","libs":[],"x":320,"y":140,"wires":[["d220d81a2fe06190"],["3335886b6ff7993b"]]},{"id":"ee833ab0cd37a661","type":"inject","z":"e4d8efb5c97ba927","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":160,"y":140,"wires":[["58a0314dfaabdb02"]]},{"id":"3335886b6ff7993b","type":"link call","z":"e4d8efb5c97ba927","name":"call subroutine","links":["ad7e14fffdc6f4fc"],"linkType":"static","timeout":"30","x":500,"y":160,"wires":[["a6c69fc023067e09"]]},{"id":"d220d81a2fe06190","type":"debug","z":"e4d8efb5c97ba927","name":"continue","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":480,"y":120,"wires":[]},{"id":"ad7e14fffdc6f4fc","type":"link in","z":"e4d8efb5c97ba927","name":"subroutine","links":[],"x":125,"y":220,"wires":[["b17ed7c9d1315020"]]},{"id":"d51c500e4fdb9c72","type":"link out","z":"e4d8efb5c97ba927","name":"link out 11","mode":"return","links":[],"x":335,"y":220,"wires":[]},{"id":"b17ed7c9d1315020","type":"function","z":"e4d8efb5c97ba927","name":"subroutine","func":"// subroutine code\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":230,"y":220,"wires":[["d51c500e4fdb9c72"]]},{"id":"a6c69fc023067e09","type":"junction","z":"e4d8efb5c97ba927","x":440,"y":220,"wires":[["58a0314dfaabdb02"]]}]
