Hello
I'm trying to use Node Red camerapi takephoto node and I receive the following error:
" Cannot find module 'uuid/v4' ".
Does anybody have an idea how to solve this issue ?
Hello
Hi
I had the same error yesterday and there is a pull request open on Github.
Fix
After I installed the node through the palette manager I went to this Github repository and copied the package.json, camerapi.html and camerpi.js files to the node_modules directory in the node-red folder and that worked
Or use a simple exec node to just grab pictures using raspistill ?
https://flows.nodered.org/flow/2b6c2f0d7a316f1a6831782d33a0d40c
Thank you, I just change uuid/v4 as they suggest and it works
