Cannot find module uiid/v4 - R Pi Camera from Dashboard
I am having this issue which seems I am going nowhere with troubleshooting:
Can you help me?
I want to take pictures using "camerapi-takephoto node". But each time I set it, it gives me the error below:
Error: Cannot find module 'uuid/v4'
Require stack:
  • /home/pi/.node-red/node_modules/node-red-contrib-camerapi/camerapi.js
  • /usr/lib/node_modules/node-red/node_modules/@node-red/registry/lib/loader.js
  • /usr/lib/node_modules/node-red/node_modules/@node-red/registry/lib/index.js
  • /usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/nodes/index.js
  • /usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/index.js
  • /usr/lib/node_modules/node-red/lib/red.js
  • /usr/lib/node_modules/node-red/red.js
Note: I did use terminal to take a photo and it was successful.
"raspistill -t 2000 -o image.jpg"
Did you install the additional modules? (https://flows.nodered.org/node/node-red-contrib-camerapi)
That tutorial is from 2017 so a lot may have changed. In the tutorial it says to modify the settings.js file.
  • which one did you modify?
  • what version of raspbian do you have installed?
  • what version of NR and node.js (you can find this in the NR start up log)
EDIT: Did you read thru the comments in that tutorial???
EDIT2: I just installed the node on a Pi B3 running stretch and it is working fine for me.
That's interesting, see Node-red-contrib-camerapi issue and the reply to it.
:thinking: What can I say, I can't remember which Pi I tried it with before and what version of raspbian. And I'm not sure I installed the pre-reqs when I tested before.
I'll have to flash a new SD card with Buster and test it out. This time I was using Stretch.
This has been fixed in node-red-contrib-camerapi v0.0.39
You can get it by stoppng Node-RED and running the following
cd .node-red
npm install node-red-camerapi@0.0.39
Big thanks to the author of the node for addressing this so quickly!
Version 0.0.40 now in the Flows library
I tried installation of specific version @0.0.39
But it doesn't seem working (same error remains).
I also tried this way before:https://randomnerdtutorials.com/node-red-with-raspberry-pi-camera-take-photos/
Another thing I realized is that when I edited settings.js file (Httpstatic), it doesn't create such directory in the home/pi directory.
  1. How did you do the update?
  2. What version of NR, node.js are you on? (see NR startup log)
  3. what os/version are you running on the Pi? (from the CLI enter cat /etc/os-release)
  4. reinstall so you pick up version 0.0.40
cd .node-red
npm remove node-red-camerapi
1- Stopped node-red and then used sudo npm install node-red-contrib-camerapi
2- It is all the latest version available. See picture.
3- It is raspbain latest from the website.
4- I will try and leave an update in here soon.
What model Pi are you running?
What model Pi? 3b, 4, pi zero?
Do you mean "node-red-contrib-camerapi"?
My bad. The Model is Zero W.
Ahhh that is an ARM-V6 whlle the 3B is ARM-V8. Both myself and the other peson with this issue are using 3B's and the update fixed the issue.
You should open an issue at https://github.com/O-Hahn/node-red-contrib-camerapi and explain you are using a PiZero-w and see what the author has to say.
Solved!
first: node-red-stop
1- I looked in every directory and deleted any type of camera module I had installed using:
npm uninstall
Also from pallete manager.
2- And I used again this method: (Important)
https://nodepy-docs.readthedocs.io/en/latest/picamera-start.html
Testing Camera: $ raspistill -o image.jpg
You should see image.jpg in the pi directory using "ls" command.
Testing Python library: $ python3 -c "import picamera"
No errors.(already had installed)
3- Noting that in the previous efforts, I had changed the "settings.js" file's "HttpStatic" folder. (I am not sure it had effect on this step.)
4- install node-red-contrib-camerapi in the .node-red directory.
pi@mysolarserver:~/.node-red $ npm install node-red-contrib-camerapi
5- start node-red
6- wire nodes.
Note that I am using dashboard.(have it installed)
7- Template node: (needs some modification)
Take a photo
Finally, The httpStatic allows you access files inside the directory you indicate in it through "http://localhost:1880/image.jpg as an example; where image.jpg is in "/home/pi/mypictures/"
